fried my ECM: HELP!!
Old May 18, 2011 | 09:22 PM
jkade72's Avatar
Default fried my ECM: HELP!!
Well I pulled a good one , I am new to tuning and fried my ecm. Swapped a 6.0 4l80e into my CCSB had hptuners support do the segment swap for the tranny. I decided I would copy and paste the remaining files from the donor file. read the warning about the desired throttle area soo I decided not to copy this I went back and changed the area back to stock or so I thought...hopped in the truck rewrite calibration and truck goes apeshit, reduced engine power ect pegs and now it wont start or even click for that matter. I guess I will visit the junk yard for a new computer, should I get one out of a 2005 half ton or can I get one out of a 2005 2500 so I wont have to do the segment swap again. I have a lot to learn about tuning, a little more to it than turning wrenches
Old May 18, 2011 | 09:27 PM
JonCR96Z's Avatar
Isn't a 'write entire' required for a segment swap?
Old May 18, 2011 | 11:45 PM
foff667's Avatar
LS1TECH Sponsor
not to my knowledge.
Old May 19, 2011 | 12:27 AM
JonCR96Z's Avatar
Ok. I've never done one, didn't know. Probably wouldn't hurt to try it at this point, though.
Old May 19, 2011 | 06:32 AM
jkade72's Avatar
Yeah I tried that and HP tuners wont commumicate with my ecm now when you try it.
Old May 19, 2011 | 06:37 AM
CalEditor@PCMCalibrators's Avatar
We offer a service to repair or replace your bricked PCM. You will not need to use any additional credits with our services. We can also get you a base tune with all the correct parameter setting for your setup.
Contact me for details caleditor@pcmcalibrators.com
Old May 19, 2011 | 11:16 AM
1969x11's Avatar
Email sent, I need to get this thing back running .
Old May 19, 2011 | 11:19 AM
salemetro's Avatar
Something to consider as well: the 4l60e segment controls the 4l80e much better. It's a pretty minor wiring change, and deleting 2 codes in the pcm.
Old May 19, 2011 | 11:33 AM
1969x11's Avatar
Care to elaborate on how this works? I had to do a minor wiring change to get the trans to work with my harnessand anything to simplify this swap would be a big help.
Old May 19, 2011 | 12:22 PM
salemetro's Avatar
PM slow67, and paypal him $20.00. Probably the best $20 that I spent on my car. He is VERY helpful.
Old May 19, 2011 | 09:27 PM
joecar's Avatar
+1 on the 4L60E segment to drive the 4L80E, need minor wiring change as said above.
The F-car 4L60E segment keeps the TCC applied on closed throttle decel (until vss drops below the TCC release curve).
We fix Bricked PCM's for $75
https://ls1tech.com/forums/14935264-post5.html
