A little information on 0411 Fuel Segments and a 98 Fuel Gauge
Hello CalEditor, I found this post looking for something and see that you have quite a bit of knowledge on this stuff.
I just hooked up an overhead console from an astrovan into my sierra and one or two of the features of the dic don't work because the pcm in the truck is not getting signal from the fuel sending unit or the guage. Like fuel range for instance. Honestly I'm not sure which feed it needs. My truck is a 96, but I recently installed a 0411 from an 01 van with the same engine in it. I just wanted to know if you had any idea which pins if any have to do with the fuel tank on a 0411 so I could try and tie in.
Hope I'm giving enough info. Thanks for any guidance.
