Fuel Level Sensor Voltage (P0463 code)
Oh and on the body harness side I switched the multimeter to ohms and got a reading of 160 ohms which is about right for how much fuel is in the tank...
http://www.tbssowners.com/forums/sho...t=P0463&page=2
Conditions for Setting the DTC
- The fuel level signal is greater than 5 volts.
- The above condition is present for greater than 20 seconds.
- The fuel gage defaults to empty.
- The low fuel indicator illuminates.
- The PCM records the operating conditions at the time the diagnostic fails. The PCM displays the failure information in the Failure Records on the scan tool.
- An open
- A high resistance
- Short to voltage
- An open
- A high resistance
- Short to voltage
Test the low reference circuit of the fuel level sender for an open, a high resistance, or a short to voltage between C101 and the fuel level sender.
Inspect for poor connections at the harness connector of the fuel level sender.
Inspect for poor connections at the harness connector of the PCM.
