Lost Ground in Starter Circuit wiring in 71 Chevelle LS1 conversion
I have been posting for awhile about how my car wont' start.. Well I removed teh VATS system from the PCM thinknig that would work and the car still won't start. I turn my key and the fuel pump and Accerssories turn on.. WHen I turn the key nothing works at all.... I used my test light and stuck it in the green power wire going to the starter relay and grounded it and the starter turned over... So basically when I ground out the system I complete the circuit..
My question is where are the grounds for the starter circuit because now I am completely lost...
Also could I just hook up a push button start directly to the starter solenoid???
