Help w/ H/C/I tuning
If I'm lucky, it can idle for a few minutes on its own before stalling. More often, only a few seconds. Attempting to open the throttle more than a tiny bit will cause it to stall immediately.
Any hints, tips, or ideas?
Scan and tune to follow...
After you get it to idle when it's warmed up (180+) you need to get you IAC counts around 40-70. You can do this by adjusting the screw on your throttle body. The more you open the throttle body the lower your IAC counts will go. You will need to reset your TPS sensor after you do this and make sure it still reads 0%.
I am assuming you have taken the proper steps to fail the maf and are actually running in speed density? Oh and I just reread what you posted, I sure hope you have changed your injector settings. If not I suggest not running your engine any longer until you get the correct injector settings. You can wash down your cylinders and spin a bearing from too much fuel in your oil. www.hptuners.com/forum
My WB shows that it's extremely lean. Even with the VE tables bumped by ~15% from where I had them pre heads/cam. I'm thinking it's so lean that opening the throttle and adding that extra bit of air is enough to cause it to stall.
My VE tables look pretty high, I can't see that the answer is just cranking them up more. Any ideas on where else to look for the solution here?
In its current state, it'll idle with just a little surge as long as I want it to. I can get it up to operating temps. However, opening the throttle to bring the revs up with cause it to die. You'll just hear it suck for air, RPM's don't really increase, and it'll stall unless you let off the gas pedal.
I'm really at a loss as to how to proceed here. What would cause this?
Turn off your long term fuel trims and leave them off.
The VE doesn't look right. The shape, or the numbers.
Put it in closed loop and try dialing it in until you get it close, then turn the short terms back on.
Log your timing in the histograms. You will probably need to add some timing in the tip in areas, instead of having it drop out.
Zero out the MAF table.
Here just try this one.
ZZZ cam starter.EH1.hpt
Of course, now it's way rich and won't idle unless I hold the throttle. I tried the settings in that tune, my old one, and a blend in between without much success yet.
So here's the puzzle. It idled reasonably well in the tune I had in before. I flashed that back with the only changes being 0's on the MAF table and the three DTC settings corrected. Now it won't idle. Why?
