2011 Camaro - Dealer detect reflashes?
The camaro I do belive is under GDS, so if you connect the new GDS/ Tech3 pretty much GM can access what we look at. So the option to change stuff back may not be there anymore.
The dealer can detect a non-stock flash (cvn numbers are different), but they cannot detect anything if it has been flashed back to stock.
Duramax ECM:
the ECM remembers the last 10 flashes so you will be found out.
On the CVN check, they can see the CVN for the last 10 flashes, so if you flashed 3 tunes to it, then restored it back to stock, they'd see 3 non stock CVNs before the stock one. No good.
That is, unless you are flashing with one of our tools that do not affect these CVNs and are undetectable once flashed back to stock.
Check out the Trinity! Visit our support forums!
Check us out on Facebook! Check out our website!
I had a 2009 Duramax in the shop that had all 10 slots filled up with the same OSID. GM didn't flash the ECM 10 times.
This is what you see on a 2011 camaro -- GDS is capable of displaying up to 10 Calibration History events.
It your tune melts down the cats why should GM pay the Bill?
We can set a 2nd ECM up. One that is OE for the days it goes to the dealer.
I took out a tranny & a rearend launching my 98 T/A at the strip, luckly the rep was cool about the aftermarket clutch and modded suspension and replaced both under my GMPP warranty I had...ahhh the good ole days I had a 2009 Duramax in the shop that had all 10 slots filled up with the same OSID. GM didn't flash the ECM 10 times.
Attachment 307138
Hey chalky I am headed up to Wisconsin to tune a few cars. Shoot me an email
but, there are other items stored in the ecm, such as odometer mileage, that they also can compare... so swapping ecm's isn't an option... because the mileage won't match the bcm/odometer...
there's a whole GM TSB out about this...
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
They want the info sent to them if the shop tech get the CVN & info.
Remember the PCM is networked in the car, other modules also report info as well.
