Codes p0102 and p0803 Need help..
Old Aug 7, 2011 | 09:58 PM
bigfatls6's Avatar
Default Codes p0102 and p0803 Need help..
I recently picked up a 6 speed 2002 z28 that had not been run for a while. The car has 47k miles has heads, ASA cam , slp long tube headers and basicly full bolt ons. It has the p0102 and p0803 codes. I tried swapping the mass air flow sensor and it still shows to have the p0102 code. It also seems kind of hard to get it into reverse. Like its hard to push the shifter over to where reverse is at. I am not sure if the previous owner had the same problem or if this is just something caused by the car sitting with out being ran. It smells like the car is also running rich at idle.
Any one have any suggestions where I should start looking first?
Old Aug 7, 2011 | 10:28 PM
bigfatls6's Avatar
Ok I found the eng sen fuse blown so now im going to have to go thru the o2 sensor wires with a fine tooth comb t osee if I can find a short. Im thinking probly on the passengers side. I saw already where some one put some kiind of heat wrap on the wires were they were close to the header on that side. Man slp headers kind of suck I guess.
Old May 7, 2013 | 07:40 PM
KILLERxSS's Avatar
did you find the solution? i have the same thing happening
Old May 7, 2013 | 07:44 PM
camarochvy21's Avatar
Old thread man
Old May 7, 2013 | 08:08 PM
KILLERxSS's Avatar
Yeah thought so:/
Old May 7, 2013 | 11:28 PM
wait4me's Avatar
some cars throwing the p0102 might just be tuned for speed density, so make sure that it is not supposed to be throwing that one on purpose.
Old May 7, 2013 | 11:42 PM
KILLERxSS's Avatar
Mine didn't have no codes when I first got it .... Could changing elevations have anything to do with it ?
Old May 7, 2013 | 11:47 PM
wait4me's Avatar
not on a p0102.. It could be bad sensor or wiring to the sensor.
Old May 7, 2013 | 11:53 PM
KILLERxSS's Avatar
Dam :/ ...somethings going on here
camaroz98's Avatar
for p102 check eng sensor fuse seems to be a big problem
Old May 7, 2013 | 11:56 PM
KILLERxSS's Avatar
Every time I replace the fuse it blows so got to figure out why
