PCM failure
Old Dec 23, 2011 | 10:47 AM
wait4me's Avatar
Originally Posted by Frozen WS6
The op stated it won't communicate at all.
Neither will mine. I've tried my tech 2 and efi live no luck. So I can't get and don't have any codes, no fuel pump, or odometer. I've got nothing. It just cranks.
Hmm ok, As long as you are sure that the ignition is getting ignition to the ecm. when key turned on, all pink wires on the harness and going to the computer should be getting 12V, and the orange wire should be getting 12v. If thats the case, then a replacement might then be needed. Pretty rare..
Old Dec 23, 2011 | 10:51 AM
Frozen WS6's Avatar
Cal. I'll get with you after the holidays in January. Gotta make sure the kids and GF have a good Christmas and new years.
Old Dec 23, 2011 | 10:56 AM
Frozen WS6's Avatar
I've been trying to follow wires to check that. That's why I replaces the key switch also because it had the wire casing cracked and had exposed the wire.
Old Dec 28, 2011 | 08:35 PM
CHEVY1MAN72's Avatar
I have a 98 camaro with 350 ls1 it roles over but it want start You can get it to start by resetting the ecm/battery & ecm /ignition fuses
Old Dec 28, 2011 | 09:51 PM
Frozen WS6's Avatar
New fuses and relays did not work on mine. That's what I checked and replaced first.
