E85- What changes in tune would yield better MPG?
Old Sep 2, 2011 | 03:16 PM
SStolen's Avatar
Default E85- What changes in tune would yield better MPG?
I've never got good gas mileage out of my set-ups. I have a new engine and turbo set-up now with E85. Only getting about 10mpg staying off it and 8.5mpg when getting on it here and there. This is city and highway mixed driving too. Wondering if raising or lowering the timing or airfuel would increase this some.
Old Sep 3, 2011 | 11:51 PM
Fbodyjunkie06's Avatar
Leaning out the airfuel will gain mpg. Doing it at idle, tip in and part throttle will get you the best mpg response to your changes. More lots and lots of timing at cruise(like 40* or more) will really help.
Old Sep 4, 2011 | 01:29 AM
The Dragon's Avatar
10!!! Holy CRAP!!!
I got 16.7 mpg city/highway on my last tank!
What Fbodyjunkie said.
Old Sep 4, 2011 | 03:17 PM
SStolen's Avatar
You get 17mpg on E85? I think you missed that part about E85.
Originally Posted by The Dragon
10!!! Holy CRAP!!!
Old Sep 4, 2011 | 04:05 PM
64nova_wagon's Avatar
I get 55 on mine//
Old Sep 9, 2011 | 02:24 AM
SStolen's Avatar
Originally Posted by 64nova_wagon
I get 55 on mine//
sure ya do
Old Jul 21, 2012 | 11:28 AM
maxgee's Avatar
Old post I know. I get 17mpg, mix of city/highway when I had 60lb injectors. A little less 15 on my 80lbs. Going to experiment with more time at cruise, I already run lean during cruise 15 to 16 AFRs.
Any progress with you getting mpg?
Old Jul 24, 2012 | 01:43 PM
white01ss's Avatar
Some info here. One guys says E85 burns faster but longer which sounds like a contradiction to me.
http://www.gminsidenews.com/forums/f...us-e10-109953/
Anyway, some say better mileage from a few more degrees of timing and leaning it a bit past stoich in the idle and cruise ranges. Good luck.
Old Jul 24, 2012 | 10:49 PM
Exeodus's Avatar
The reason you get less gas mileage with E85 is because it has less BTU's than gasoline. You might gain 1 or 2 MPG by leaning the AF ratio, and the 105 octane of E85 gives you a little more of a safety net than gas, but would it be worth the risks?
Old Jul 24, 2012 | 11:32 PM
I8UR4RD's Avatar
I think it may burn longer much like alcohol.[/I], I also think it burns cooler and produces less emissions, but has a bigger boom in the combustion chamber due to it being like a higher octane fuel. correct me if I am wrong. there have been some tests done that I found interesting.
Old Jul 25, 2012 | 10:34 AM
white01ss's Avatar
When converting from gas to E85 compression ratio is an important factor in getting all the power possible from the fuel. If you raise your compression ratio from 9:1 to 10:1 at the same boost level you get better mileage and peak power, but you can't easily go back to gas.
Good writeup about E85 from a turbo volvo forum:
http://forums.turbobricks.com/showthread.php?t=73061
Old Jul 25, 2012 | 10:46 AM
three83'camaro's Avatar
considering it takes 25-30% more fuel to achive lambda 1.0 with E85 over E10 I would think that if your running E85 then MPG wouldnt be a concern knowing its going to be terrible.
