how long does it take PCM to learn?
Old Mar 8, 2004 | 08:11 PM
mako22's Avatar
Default how long does it take PCM to learn?
have the Predator tuner and just removed the perf. tune and returned the stock tune. the car has been running a little rough, w a little KR and I'm curious to see what happens without the tune. my question - how many miles does it take for my car to really get back to stock?
Old Mar 9, 2004 | 07:48 AM
jimmyblue's Avatar
Moderator
Not really miles, how the long term trims learn is
by the magnitude of the short-term error and
the sime you spend in a cell. Cells like idle and
your most-common cruise points learn out quick
(by clock-on-the-wall time) but cells you use
seldom or briefly will take a longer while to get
their "time in the saddle" and smarten up. It
could be a week if you have very fixed driving
habits. Try and mix it up, more 1/4 to 1/2-throttle
acceleration for no reason. Predator seems to add
some PE with its tune and pulling it has probably
confused the higher-TPS cells lean.
Old Mar 9, 2004 | 08:41 AM
mako22's Avatar
Jimmyblue thanks for the info. I'm going to leave the factory tune in for a week and then after I get my headers and gears installed get a custom tune done from the predator guy and install it - does that sound like a good plan? If I'm still getting knock retard, should I mess with the timing (increase?) I know I should just go and have it dyno-tuned but I spent $400 on this Predator I want to give it a chance.....
