A/F questions
Old Jun 3, 2004 | 12:02 PM
Sunset01's Avatar
All city? Pushing the car or not all ? How many miles on the oxygen sensors?
Old Jun 3, 2004 | 12:03 PM
TIMMEH's Avatar
like...500 if that. Yes all city, no WOT runs.
Old Jun 3, 2004 | 12:54 PM
Sunset01's Avatar
Ok, if you don't have scan software, you need it. Check engine light? You need to log ltrims, maybe fuel injector pulsewidth. Do you have stock injectors and stock computer. You have a list of all mods ? stock maf?- if not, all bets are off.
Old Jun 3, 2004 | 01:44 PM
TIMMEH's Avatar
stock MAF... I adjusted the IFR to bring the ltrms into the negatives, close to 0. Stock PCM and injectors.
Old Jun 3, 2004 | 02:29 PM
Team ZR-1's Avatar
Originally Posted by Sunset01
But the PE vs. RPM is only for WOT. If you aren't on the card hard a lot, you shouldn't be killing the gas mileage, as you should be then in closed loop and the computer/O2s normally do a great job of running at 14.7 AF.
PE is not only for WOT.
WOT is when engine is at 100% engine load as per EPA,
PE can be functional as little as 25% on the gas pedal depending on RPMs and MAP value so PE is used a lot more then when in true WOT.
Old Jun 4, 2004 | 10:21 AM
TIMMEH's Avatar
Well I can't afford filling up every 3 days anymore, I'm getting a dyno tune today. Hopefully this will alleviate all my issues.
