A/F questions
bung-substituted wideband or a tailpipe unit or
If you make the car richer, you slow the burn and
need to add timing advance to find peak power.
When they got to 13.0:1, did they then jack the
timing forward to find the knock limit? Or only at
the leaner (14:1) point later?
Yes he advanced the timing with the fuel in the correct range.
I am not sure about the last question.
Setup: I have a Dynojet 248 (high inertia), dynojet wideband, LS1edit, efilive, and perform backup checks for AFR accuracy with a techedge unit as well as a backup sensor in the dynojet. These checks were performed Friday, and again this morning with no discrepencies found.
I tune a lot of LS1's and usually if they start lean, say 14.5:1 I can fatten them up to 13.5 and GAIN power, then lose slightly dropping from 13.5 to 13.1 or 13.0. This car made max power at 14.0/13.9, and behaved as if it was being over-richened as AFR was dropped to 13.0. At no point did the graph show signs of detonation until AFR was 14.0 and timing was 29*. Max power was made at 26* and 14.0. I usually see max power at 13.3-13.4!
Let's look at my race car experience: I see motors that like to run fat and make max power at 12.2:1 NA. And motors that want to run lean and are happy at 14.2 or 14.4:1, as long they are not detonating, no damage is being done, as long the motor is "happy".
Agreed, this is a weird one. I won't say I lost sleep over it, but it is weird. Everything about the behavior says set it at 14.0, except conventional wisdom. The car I tuned today (also an LS1) made max power at 13.2:1.
As I've told Brandon, the options are:
- monitor things, check the plugs, listen for detonation, stay the course.
- bring it by and I'll fatten that sucker up with the MAF that's in it.
- change MAF to stock, bring it back, re-tune it.
I think they are all decent options. I know he's scared and I'd be scared too if the car showed me any signs of not wanting to be set where it's set.
This is an odd one. Agreed... Anyone seen a computer controlled car that made max power at so lean an AFR??
Weird stuff....
-jeff
Weird stuff....
-jeff
joel
Other option I considered and dismissed was completely unburt fuel shows lean on narrowband and wideband sensors. But it would have had to be 2 cylinders down though, because the narrowband O2's were closely matched.
Twilight zone maybe, maybe not...
-jeff
joel
I need help tuning this damn thing.
