02 volts - Good? Bad? Indifferent?
Can someone take a look at these numbers and let me know if my o2 sensors and sims are working properly?
I'm getting about 13 mpg which is down quite a bit, so I'm trying to figure out what the problem is.
Thanks guys
Run 1: 3.3 Miles, Average speed 16, Max 50
B1,S1 - .91V
B1,S2 - .80V
B2,S1 - .96V
B2,S2 - .77V
Run 2: 3.4 Miles, Average speed 23, Max 55
B1,S1 - .90V
B1,S2 - .83V
B2,S1 - .91V
B2,S2 - .79V
Run 3: 1 Miles, Average speed 23, Max 50
B1,S1 - .91V
B1,S2 - .80V
B2,S1 - .90V
B2,S2 - .78V
Run 4: 1.4 Miles, Average speed 13, Max 37
B1,S1 - .94V
B1,S2 - .81V
B2,S1 - .96V
B2,S2 - .77V
Run 5: 2.5 Miles, Average speed 19, Max 50
B1,S1 - .90V
B1,S2 - .81V
B2,S1 - .90V
B2,S2 - .77V
Run 2: 3.3 Miles, Average speed 17, Max 49
B1,S1 - .89V
B1,S2 - .81V
B2,S1 - .92V
B2,S2 - .77V
Thanks guys
B1,S1 - .91V
B1,S2 - .80V
B2,S1 - .96V
B2,S2 - .77V
B1,S1 - .90V
B1,S2 - .83V
B2,S1 - .91V
B2,S2 - .79V
B1,S1 - .91V
B1,S2 - .80V
B2,S1 - .90V
B2,S2 - .78V
B1,S1 - .94V
B1,S2 - .81V
B2,S1 - .96V
B2,S2 - .77V
B1,S1 - .90V
B1,S2 - .81V
B2,S1 - .90V
B2,S2 - .77V
B1,S1 - .89V
B1,S2 - .81V
B2,S1 - .92V
B2,S2 - .77V
Popa,
Are your O2's going lean/rich/lean/rich... ie the voltage should go low/high/low/high. If they are sitting still and 800-900mV....you've got a problem. What are you using to tune? Post your current tune and a log.
