Tuners are you using narrow-bands to tune?
I thought I saw on here somewhere were a sponsor was modifing the factory PCm some how. I know they open it up and ad or change some things to it. I do not remember what the added hardware did for you or if it added WB control to the factory PCM.
You are right, it would be nice if we could utilize a WB with the factry computer. I only wish someone made an aftermarket PCM that would drive the factory dash. I know of several that will or do control the 4l60's and 4l80's but none that will also control the dash. That is they only reason I have not gotten away from the factory PCM even though I should. I have not found a solution for the Dash yet.
You can use them to log WOT but I would only suggest NA applications. Should most people -no. You have to know what your looking at. A tuner should use a wideband to verify/set everything.
For my personal NA cars I've always just gone by the nrrowbands. When checked on the dyno the A/F's were correct.
A common misperception of narrow-bands are that they work at or around 14.7 to 1 AFR and it has nothing to do with that. GM uses narrow bands for E85 vehicles with the Stoich of 9.7 to 1. The narrow band have a shorter area that they can control the fueling. This narrow band if about .5 up and down from the set switching Stoich. I didn’t say it couldn’t monitor the EQ of the AFR. If you know how the O2 will respond to the target EQ then you can use a narrow band it just won’t control the fuel, but you’re in PE anyway
I was refering to a DTC like this
The PCM detects that the HO2S 2 signal voltage remains below 550 mV during power enrichment (PE) mode and the Air Fuel Ratio parameter is below 12.5:1 for more than 25 seconds.
But by that you meant that the computer would not use the narrow band to change fuel trims I assume. But I guess a better way to put it would be you are in closed loop anyway so the narrow band will not control the fuel trims.
A NB tells you only 2 things, you are richer than stoich or leaner than stoich. Nothing more. Doesn't matter if you are running Nitromethane with a 2:1 AFR. Doesn't matter, the way a NB works it doesn't care. Diesel would be fine, it just doesn't matter. It only tells you rich or leaner than stoich.
Any competant tuner would tell you HELL NO! Would you ask for a dyno tune without a wideband? Spend the extra $250 and buy a wideband. Your already in atleast that even if you purchased your tuning suite used. Protect your $1,500+ motor ya goofs, seriously!
