Help with VE tuning....log and tune inside
Brandon
Your engine temp. and the outside air temp. (IAT) are too high!
The knock in your scanner log @ 800rpm-1,200rpm is unacceptable.
Changes:
VCM Scanner > Histogram Display > Histogram Configuration > Cell Hits Required > Histogram 7 (VE-AFR error) > 5-20 as you want ONLY good data NOT random data that updated 1 time.
VCM Editor > Engine > Torque Management > General > Traction Control System TCS Method > Retard vs. RPM > Put back in stock values.
VCM Editor > Engine > Torque Management > General > Spark Retard > vs. Torque Reduction > 0 out all.
VCM Editor > Engine > Torque Management > General > Torque Loss % > vs. Spark Retard > 0 out all.
VCM Editor > Engine > Torque Management > General > Maximum Torque Max Torque > 640 ft.lb
VCM Editor > Engine > Spark > Advance > Main Spark Advance > Low Octane > Copy to High Octane once done tuning, then copy High Octane x 80% (.80) so you have low octane safety timing net.
VCM Editor > Engine > Fuel > Power Enrich > Power Enrichment > EQ Ratio vs. RPM > start with all 1.16 (AFR 12.5'ish) , NOT 1.00!
VCM Editor > Engine > Fuel > Open & Closed Loop > Open Loop > EQ ratio > match it to your Power Enrichment table while tuning, hit a single target (i.e. 1.16:AFR 12.5'ish).
VCM Editor > Engine > Fuel > Cutoff, DFCO > RPM Limits > P/N Cutoff > 6,500rpm and P/N Resume 6,400rpm.
VCM Editor > Engine > Fuel > Cutoff, DFCO > Cutoff RPM vs. Gear > Normal > Cutoff 6,500rpm and Resume 6,400rpm.
P.S. Answer yes. Your hand smoothing looks good. Keep up the good work!
Search on www.HpTuners.com/Forum : HPT_Injector_Calc.xls (Injector Spreedsheet)
Open it...
I entered
4B= 43.5
5B= 58
6B= 48
Line 26C-26S = I was given the following to enter in order in table Flow Rate vs KPA:
55.4266032953 55.7720386999 56.1153477101 56.4565691175 56.7957405481 57.1328985112 57.4680784452 57.8013147607 58.1326408823 58.4620892874 58.7896915431 59.1154783421 59.439479536 59.7617241668 60.0822404982 60.4010560435 60.7181975939
__________________
ps....measured at the rail with pod mounted gauge and sender
