VE Table Cracked
http://www.efilive.com/forum/viewtopic.php?t=455
Here you go
2349 / 30 = VE% 78.3
2349 / 28.96 = VE % 81.11
81.11 / 78.3 = 103.58%
Hope that cleared it up
Max VE should be 3000*103.58 - I believe. It never has been settled, vs another #,
that I know of.
Anyhow, NoGo said to scale previous VE #s by 103.58 as a correction factor. It just so happens EFILive was using the equation ChrisB and NoGo ironed out.
This is my take on it.
joel
Should I be waiting to modify the Main VE until I have literally all the cells mapped? I have 133/380 mapped now. How am I supposed to get the 400/800 & 7200+ entries when my idle is above that? Just interpolate and try to make the curve smooth with the rest of the entries?
Yup you wont be touching anything above 7200 anyways. When I log I dont hit all the cells that is why i was asking how to hand smooth this thing to make any transitions easy
that I know of.
joel
If the displacement is already included in VE values I would expect the maximum possible value (for 100%) would be higher, but how to figure the number?
Thanks
high-falutin' theoretical stuff.
Is 0.773 g/cyl still believed to be the 100% VE,
100kPa-ambient "right value"? And is the dynamic
cylinder air PID we get out of (say) HPTuners, a
MAF-only derived result (that is, not colored by
any VE / SD-related calcs)? And if these are both
true, and we believe our MAF data, then could /
should a shade-tree laptop tuner use that
PID/0.773 value to check and/or massage VE
tables to try and true things up, pointwise?
I appreciate all the help and useful information from everyone. I agree that you can't just "calculate a VE table" to improve your car's performance. However, I would like to see someone other than myself address the issue of the differences in MainVE tables between engines of different displacement.
From looking at truck PCM calibrations, the maximum value in the main VE table varies quite drastically based on engine displacement. I believe gameover about the cylinder displacement being included in the Main VE table, it makes perfect sense when you look at calibrations for 4.8L engine versus 6.0L engine. Max EditVE for a 4.8L is 2093, and for a 6.0L its 2679. There is no way these calibrations are on the same scale... (i.e. if 100%VE = 2900 for all engines, then the 6.0L engine would be so much more efficient that everyone would have one.)
On your question, I think the correct 100% VE value for a 5.7L engine has been determined by several methods (both from mathematical analysis and from logged data) to be around 2896 to 2902 in Edit units. Translating this to g/cyl.... uhhh, assuming the max value for a 5.7L is 2349, that makes 81%VE. So divide your max value (g/cyl) by 0.81 to get 100%VE value.
The units of the table are: grams.Kelvin/kPa ie. at a given temp and pressure it will give you the cylinder airmass.
For example: a 5.7L engine has a cylinder volume of 0.708L, and at 101kPa and 20degC (293K) you get an airmass of 0.85 grams at 100% VE (ie. 0.708L of air at 20degC, atmospheric).
the table value is: V(L).(M/R).5120 g.K/kPa
V(L) is the effective volume, M=28.98, R=8.3144 and the 5120 is the internal scalar (internal binary-decimal storage).
To express this as a VE% you can just normalise to the cylinder volume. you'll see that M/R = 3.485 and (3.485).5120 is 17833, the factor i mentioned a few posts back.
Important thing to remember, you need to multiply by the MAP and divide by the AirTemp (in kelvin) to get the actual g/cyl value.
For those running HPTuners s/w to get g/cyl from the VE table multiply your VE% by 178.33, and then your cylinder volume (5.7L = 0.708). Then multiply by the MAP and then divide by AirTemp and the internal factor.
eg. if your VE is 100% at 20degC, 101kPa then:
100 . (178.33) . (0.708) . 101 / (293) . 5120 = 0.85 g/cyl
How come rpm isnt taken into account here
There is a VE PID that is equal to Calulated Airmass / Ideal Airmass. Where Ideal Airmass is how much air that would be in the full cylinder volume, current temp and Baro pressure. It's limited to a max of 100%.
In the VCM Scanner under Engine -> Airflow
If you want to estimate VE from other sources such as the MAF then yes you need to take into account RPM, the numer of cylinders etc. I'm talking only about the VE table here.
My reference to rpm was asking about the formula. I undertand the ve table is scaled by rpm. If i wanted to use this formula for calculating a new ve table I only have one axis to go by.
Am I looking at this the wrong way?
joel
