LS1 PCM in a S10 1993 truck ??
Hi
i´m gona try to help one guy out
he´s swapping a ls1 to a S10 truck 1993 model and it doen´t start up![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
what exactly do i need to do to dial it in /pair them together and have it start up.
thanks
Baezi
thanks
Baezi
i think the wiring is wrong to fuel pump
ok i turned VATS off
and the car just started , no fuel and no spark
we went over wires and we found out that he forgotte to fasten 2 grounds near the ignition back off the driversside head , we fixed that
started the car , the ignition came in but still no fuel, i commanded fuel pump "on" in the scanner and i heard a click in relay but the fuel pump was still off. No fuel to rails
So would you say that it´s wiring related or am i missing something in the tune maby
thanks
Baezi
thanks
Baezi
stock fuel pump? If you heard the relay click and no fuel, I would make sure you are getting power to the fuel pump (should be if you guys did not touch the stock harness back there. But if you are getting power to pump than change the pump out.
Who's wiring harness did the guy go with?
the guy just called me he went over the wiring again, the pump wiring was right but the power from switch was wrong wired
problem solved and one happy LS1 swapper more
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
thanks for your help guys
Baezi
