Cylinder 6 misfire!!!! Help!!!!!
I thought the samething, so I moved the lifters from cylinder 6 to cylinder 2 and the misfire stayed on cylinder 6. I also moved the pushrods and rocker arms to cylinder 2 and the misfire stayed on cylinder 6.
Removed the new custom grind cam from comp cams and replaced it with a factory cam and the missfire went away. Lucky speed is in the process of sending it back for inspection and replacement.
I have the same problem you do except mine is not firing on 3 and 5. I have posted on this site with no reply. Have talked to experts around here even the guys in ark at street and performance. They just tell me to check stuff I have already done .
If I understand it right, If two cylinder that are side by side are missing then the most likey cause is a bad head gasket that is sharing compression from one cylinder to another or a bad lifter.
