Flashing SES...help!!??
Check the plug wires, if they're sound (tight on plug and on coil pack, no physical damage) check the spark plugs, if they're sound then I'd prolly pop the valve covers next and check there... if you can autotap it watch the misfire count for all cylinders and see which cylinder is showing the highest count.. (should be obnoxiously high)
