Hanging Idle and "Cruise Control"
Old Dec 20, 2013 | 12:48 AM
Fourth-Gen Man's Avatar
No problem man. Anything I can do to help any of my fellow LS engine owners. My mechanic called me over and showed me the smoke test so I could see the leaks for myself after he found them. He removed my lid/MAF. Then he attached a hose into the air bellow from where the MAF connects to the throttle body. On the other end of this hose was an air compressor on a low setting that was pumping in air that was filled with some kind of white smoke. So he turned the air compressor on and opened up the blade of the throttle body so after a minute as the intake manifold filled up with this white smoke, the pressure inside the intake started to rise and it was looking for a way to escape. In result, it starts seeping out of all of the places where you have a vacuum leak. So instead of spraying cleaner everywhere and trying to find the leak, you just wait a minute with the smoke test and you can actually see with your own eyes where the smoke is leaking out of. It does not damage anything either since the compressor is on low and there is openings where the compressor's hose attaches to so the pressure does not get too great.
Old Dec 20, 2013 | 08:35 AM
dannyual777's Avatar
From: Montgomery (Lake Conroe,) TX north of Houston
Thank you so much for that description of the smoke test. I think that I could rig something up like that to troubleshoot my car. I hate spraying all of that carb cleaner on everything since it's so harsh.
My car is burning more gas than normal so I know that something is wrong (vacuum leak?) causing the high idle. Gotta find the problem.
Old Dec 20, 2013 | 08:54 AM
aknovaman's Avatar
Concerning the smoke test, doesn't all of it go straight out the cylinder that has both intake and exhaust valves open during overlap?
Old Dec 20, 2013 | 08:59 AM
Now that's a good question.
Old Dec 21, 2013 | 12:31 AM
You would think that some of it would go through there. Some probably did. Maybe the compressed air was warm so it rose to all of the openings from the top first? One thing I did not note is that my mechanic told me I had to leave my car there overnight because the smoke test works better "when it's cold". I don't know if by "it" he meant the engine or the outside environment. The mechanic I went to is not too far away from where I live so next time I'm around there and he does not look too busy I will ask him the details about that. It was pretty cool being able to visually see where all of my vacuum leaks were though!
Danny: I do not know if you have checked that hose that is between your PCV valve and your intake manifold but I would really check it out if I were you as I found it is very very common for that to go. Also my actual hose there was in fine shape but it just didn't have a very good seal to the male ends of each side. So I put the hose clamps on each side. You might just wanna give that a try because I have been finding that it is a very common place for vacuum leaks in our cars.
Old Dec 21, 2013 | 02:37 AM
BigEd_72455's Avatar
I read some place about the smoke test being done. it said in the article that they "capped" the exhaust at the tailpipes.
Considering you could do that with just a pipe cap made from pvc (plumbing store) and a piece of boot from like an intake kit, it should not be too hard to figure out how to do.
Thinking about it, a really low buck version would be to light a cigarette down the intake tube away from the throttle body, leaving the tube pointing up. Smoke rises up the tube and into the intake looking for a way out, regulate the pressure of an air gun down to say 10 psi and make a cap setup for the intake with a small port to allow you to pressurize the tube. Couple short squirts up the tube forces the smoke filled intake air out any leaking spots. Have one person giving the short spurts, and the other (owner having to deal with the hassles) looks around the engine bay for where it could be leaking.
Old Jan 5, 2014 | 11:59 AM
This high idle problem is driving me to madness . I don't even want to drive my car anymore and I find myself avoiding it and driving one of my other old cars. I'm sooooooooo !
I tried looking at that PVC hose but it's completely encased in some type of outer insulating, foam rubber type material. Not only that, it seems to be secured down to the intake manifold and there seems to be a bunch of fragile plastic clips and what not all near that hose making it impossible for me to see anything but the very end at the front of the engine. I did notice that it seemed to be loose on the PCV valve so I also clamped it.
I've also had screwy temp gauge readings so I purchased new OEM parts; engine coolant temp and air intake temp sensors and installed them. None of this has helped and I've still got high idle speeds.
I know I'm going to have to fight that complete PVC hose out of there but I just know that I'm going to destroy lots of little things and probably make even more trouble for myself.
Old Jan 5, 2014 | 12:27 PM
Anthony Williams's Avatar
Well I had the same problem after getting my new motor tuned, turned out to be the TPS. Seems they can just start to go bad and cause all sorts of funny issues WITHOUT throwing a code. They can be tested, but new only cost around $30. Good luck!
Another way to find out if it is a vacuum leak is to get it smog tested and see if your putting out high HC.
Old Jan 5, 2014 | 01:08 PM
Anthony thank you for your reply.
I'll keep that TPS in mind but the smog test thing is a not an option where I live.
I keep thinking that my idle speed problems are temperature related.
1. On cold start up, the engine idles higher than it used to and stays high until the engine gets nice and warm.
2. Most of my trips are very short, less than 3-4 miles one way. Often the engine never reaches full operating temperature and my rolling idle speed with the clutch pedal depressed is about 1000rpm. This is quite a bit higher than it used to be! Once I come to a full stop, it falls to about 750-800.
3. If I drive further (10 miles) and the engine is up to temp, I notice that my idle speed problems disappear. It seems to idle like it did when new with a rolling idle speed of about 750-800 with the clutch pedal depressed (neutral.) When I come to a complete stop, it falls another little bit to about 700rpm.
Like I said, this all leads me to believe that it's temperature related so I replaced two of the temperature sensors (ECT and IAT) and all it did was lighten my wallet. I know deep down inside that the problem is most likely what Fourth-Gen Man says; it's the dreaded, difficult to find vacuum leak !
Old Jan 22, 2014 | 09:57 PM
Sounds pretty much identical to what my car was doing. Your description of the PCV hose was interesting to me though. Because the foam type insulation you were referring to is not AROUND the PCV hose. You see it is just a small rubber hose that you push into the male connectors of the PCV valve and the side of the intake manifold. It is the actual hose itself. You should be able to just pull that thing right out. I just threw a hose clamp on both sides for a better seal on the male ends it was resting on. By pulling it out you shouldn't harm a thing. Not sure what all the plastic clamps you were talking about are from.
I have found a couple threads of people claiming this is their only issue and it solves the problem. Hopefully it's the same for you.
Old Jan 26, 2014 | 06:39 PM
Fourth-Gen, here is a pic of my PCV (at least I think this is the PCV):
I think that is the PCV because this is what I found on Install University:
This Install University picture came from: http://www.installuniversity.com/ls1...alve-swap.html
Here is a picture of me pointing to the soft rubber insulation covering the PCV hose:
And here I am pointing to the hard plastic PCV hose inside the insulation:
That hose continues aft along the intake manifold and then way up under the cowl, it appears to wrap around toward the driver's side. I looks almost impossible to get to the aft part of that hose back there. I'm going to have to figure out where it goes because I need to remove it to determine if there are any leaks in it.
I call it a hose but it is more of a hard plastic pipe. I'm hoping that I can get it out and that it has a hole in it somewhere. That would be the "smoking gun" that I'm looking for.
FWIW, my car is a 2002 WS6 and the Install University car is a 1999 Z28.
Old Feb 11, 2014 | 03:16 PM
  #32
Yeah that first picture you put up is where I threw the two hose clamps. That's where my biggest leak was and where others seem to develop leaks as well.
Old Feb 11, 2014 | 03:22 PM
  #33
thunderstruck507's Avatar
I did a smoke test on mine with the rocker arms off so all valves were closed. Used a tire pump that had both a in and out line for blowing up rafts and hooked it draw from a hookah.
It pushes 6 psi and I had no looks so I would say now I can be certain mine is not vacuum related.
Old Feb 11, 2014 | 03:23 PM
  #34
Old Mar 7, 2014 | 10:23 AM
  #35
A couple of weeks ago I added 3 clamps to make sure none of those PVC connections were leaking. Here is a picture:
Unfortunately, it didn't fix the problem. The idle speed is still high so something is still wrong .
I would like to inspect the rest of that PVC hose but it goes along the passenger side of the intake manifold back towards the rear and the the cowl of the car gets in the way. I can't even see where it goes or where it connects to the engine. If someone could tell me where it goes and/or how to remove it, I would so that I could determine whether or not there is a leak in the hose or where it plugs into the engine.
Old Jan 16, 2016 | 02:43 PM
  #36
caturnbull1's Avatar
i know this is old but dannyual did you ever fix the problem? my car is doing the same thing.
Old Jan 16, 2016 | 06:26 PM
  #37
My car's idle problem has "morphed" in the last year or so.
About this time last year, I noticed that the high idle speeds were mostly gone when I wasn't using the ac. I did notice that I would almost always have high idle speeds with the ac on during warm Florida winter days but when the weather would cool down and I turned the ac off, my idle speeds were back to normal.
During the summer of 2015, I experienced the same thing with the ac on. Idle speeds were higher than they should be: 900-1000rpm with the ac on. If I turn the ac off, the idle will drop down to 700rpm. I've owned this car since I took delivery of it brand new on 13 Sept 2001 so I know it like the back of my hand. In it's younger days with the ac on, it did not idle at 900-1000rpm.
I know it's like comparing apples to oranges but my 5-sp, 1991 Mustang GT doesn't idle at 900-1000rpm with the ac on and neither does my automatic, 2001 F250SD diesel truck whether in gear or neutral.
At least the car doesn't frustrate me in the winter time. However, those summer high idle speeds really make me feel !
Old Jan 17, 2016 | 01:49 PM
  #38
my car does it everynow and then. ive noticed if i let it warm up all the way from a cold start it wont do it. but when i turn it off and back on it will do it
