vette tuning. tb issue?
Old Jul 10, 2012 | 01:35 PM
SKULL's Avatar
Default vette tuning. tb issue?
03 z. monster. stg 3 light weight flywhel. fast 90, ls2 tb, dynatech longtube with 2.5 x pipe. problem occured after frost tuned it and also changed the tune back to reading the maf instead of speed density from when my friend tuned it. took the car to the track a few weeks ago. when shifting into the next gear and getting back on the gas. the car feels like it is hesitating or is a delay in how fast the tb response. happens in every gear for me and 2 of 3 shifts for another friend. last week i got a code 1515 also(havent found any answers on how to fix it besides that it might be a lose connection but everything looks perfect). i then took the car out and logged it and did some no lift shifting. between shift while doing zero lifting, the tb was recording 100% down to 20% when changing gears, then back to 100%. (i never lifted.)
is the tb closing because it is automaticly doing it or is it because im shifting at redline and hitting the limiter? if it is the tb automaticly closing on its own, how do i turn it off?
thanks for any help givin because im for the last 2 weeks trying to find answers why its having this problem between shifts and its killing my times at the track
Old Jul 12, 2012 | 08:31 AM
SKULL's Avatar
bump
Old Jul 12, 2012 | 08:38 AM
06X6spdGTO's Avatar
Rev limiter doesnt control the throttle blade, only timing and fuel cut. Do you have hptuners?? If so post a copy of the tune plz.
Old Jul 12, 2012 | 10:09 AM
SSpdDmon's Avatar
Is there a torque management table interfering?
Old Jul 12, 2012 | 01:08 PM
SKULL's Avatar
tq management has been maxed out on all tables so it shouldnt be interfering. ill have my friend post up a tune when he can(yes hp tuners)
Old Jul 12, 2012 | 06:32 PM
BLK02WS6's Avatar
On ETC cars, there is an enabler for the ETC to perform rev limiter functions... and when you push in the clutch, it is going to use the P/N values because clutch in always uses those tables...
Old Jul 13, 2012 | 06:28 PM
SKULL's Avatar
So how do I make the etc not do that? Also is that why when I hit like 6200 the car completely dies then picks up and goes to limiter at 6500
Old Jul 13, 2012 | 11:24 PM
06X6spdGTO's Avatar
Maybe Im not up to par but the only limits I can find on the ETC is in Torque Management, ETC TPS Max. Leave the top row at 0, High light everything from 10-100% and across to 8000rpm, change to 100%.
Old Jul 16, 2012 | 02:31 AM
SKULL's Avatar
Thanks alot for the help. It ended up being the etc table was 300 rpm lower then what the rev limiter was set to. This makes such a difference in the car and how happy I am with the car words can't describe it
Old Jul 16, 2012 | 05:38 AM
BLK02WS6's Avatar
Glad you got it straight...
Old Jul 16, 2012 | 09:39 AM
bad6as's Avatar
ect and the rev limiter were the same, raised the revlimiter a tad and raised the ect a couple hundred more then the revlimiter
vettes and fbodys have ALOT of diff tables. glad its fixed for sure.
now to mess with dfco to let it shoot some flames = p
Old Jul 18, 2012 | 09:57 AM
SKULL's Avatar
Minimum 3ft flames
