MAF and O2 issues?
At idle my MAF only reads 4-5g/sec. Goes to 8g/sec at 2,000rpm.
Both front O2 sensors read 900 at idle and stay there. If I give it throttle it will go down to 70 and then stay back at 900.
What do these readings tell you? I am trying to get this car tuned, but they want me to fix these issues 1st.
warm idle. Of course you do have the blower load that
will add to that.
Look at how MAF compares to dynamic airflow g/sec.
I think you're not really running off the MAF at idle, a
fraction blended in perhaps. With as lean as it's reading
for you to be showing such high O2 voltages, says to
me you may be in PE / open loop mode (enriched above
stoich due to high MAP w/ blower load?) and using the
dynamic airflow for fueling - otherwise you'd need an
opposing bit of crazy on the injector flow side to make
it up (and then some, to get pig rich).
Now being pig rich is also going to elevate idle MAP
more, perhaps leading to additional enrichment, on and
on.
One issue I have is that I really have no idea what Speed Inc and then FLP did to my PCM. I would have expected FLP to override everything Speed Inc did when they allowed the car to run on the 60lb injectors. I would have also expected them to ensure the settings on the PCM were correct since they did have it on the dyno at one point. FLP says it is not a tuning issue?
If you can, post a copy of your tune and someone will take a look at it. But, check for mechanical issues as well...
Makes sense about the tuning issue. Frustrating since the tuner shop says the tune is setup fine.
it could also mean the MAF is too close to the throttle blade (the bottom opening blade distorts the airflow to the lower part of the MAF).
Also to note. The tubes that I had disconnected and saw the rise in g/sec were the two tubes going into the polished plenum box. So the MAF to TB was the same in that respect.
the blower; air mass is constant if your leaks are fixed.
Maybe put it all the way up at the inlet. There might be
some transient inaccuracies but then the thing would
be falling back to SD anyway during unsteady-MAP.
Just find some section somewhere that has a straight
or straight funnel kind of geometry (seen blower setups
with a K&N cone type filter and the MAF at the base of
that - not an oiled filter fan, but the plain plumbing
looked kind of right).
MAF Freq ~2260Hz
MAF g/sec - RPM (Done in park)
- 5.75 g/sec @ 600
- 8.50 g/sec @ 1000
- 19.30-22 g/sec @ 2000
- 35-45 g/sec @ 3000
Front O2s, both banks = 955mV
blower's lost oil has coked it up over time?
Ever swap in another, right-reading screened MAF from
another vehicle, just to see if it's the piece or its
environment?
Sounds like the min pulse width isn't low enough and possibly they took fuel out of the maf table to try and fix it but didn't work. You really need to get someone with hptuners to pull the file and post it up so we can see what it going on in the pcm.
