Need help understanding a STFT problem!
Old Aug 11, 2012 | 05:48 PM
outkast6991's Avatar
well just an update after the intake swap. When i pulled the old intake the repair actual doesn't seem to be the leak. it looks like the MAP sensor/vac port fitting is the problem. It has a decent amount of movement to it. i'm thinking a little epoxy on it and it will be fine. i installed the new intake and to my surprise the car actually doesn't run that bad. the idle is rich as well as part throttle. the STFT's are -10 at idle and between 0 and -13 at part throttle. the iac count on hot idle is 90-110. a retune is in order for sure
Old Aug 11, 2012 | 07:12 PM
BLK02WS6's Avatar
Originally Posted by outkast6991
i think this is the road i'm gonna take. i just wish they still sold v1. the entry price of v2 has kept me from pulling the trigger for fear that i wont be able to pick it up and end up with a $900 code reader. LMFAO
LOL! You can do it. I can help you along the way.
Old Aug 11, 2012 | 07:14 PM
BLK02WS6's Avatar
She was definitely leaking! Glad you are getting it straight...
