PCM Placement
Old Aug 10, 2012 | 02:34 PM
Chrome_Rust's Avatar
Default PCM Placement
I am at the stage in my build where I need to think about wiring and where I want to put stuff. My 93 has a SN95 dash swap, and space is at a premium behind it.
I was thinking, since I am doing a rear seat delete (I am 6'5", and have 01 GT leather seats) I want to put my PCM where the passenger rear seat used to be. I'd like to make a compartment on either side (I am going to make the compartments anyway) one for the PCM, and the other for power distribution. I also want to make them both seen (Used to professionally install car audio) and clean, but throw a little flair in on the mix with some LED lighting in a tasteful fashion. I also want to window my PCM, and install some lighting inside it (did many PC case mods also.... google my screen name, you will see....)
Now for the placement issue. I want the PCM in my back seat, will there by any issues extending the signal wires that far? I am only extending the signal wires. The power/ground wires will go to the distribution area on the drivers side, and the engine side of the power/ground will go to another distribution area in the passenger kick panel. I am thining in total a length increase of 6-7' max. will this cause any signal degradation or interference issues. I am planning on using some foil tape to limit the amount of intereference om the wire bundle, so.... What are your thoughts?
Charlie
Old Aug 10, 2012 | 03:13 PM
salemetro's Avatar
Charlie
I'm running the PCM on the back deck of my Miata swap. So far (12k miles), no problems. I think you'll be fine.
Old Aug 10, 2012 | 03:52 PM
What did you do for the wiring, did you shield it? Have any pics of it?
Old Aug 10, 2012 | 04:03 PM
salemetro's Avatar
Just extended the harness roughly 6 feet using wires from another harness. Solder and heat-shrink as per usual. Battery is mounted in the trunk in Miatas, so a few of the relay'd/fused power supply lines for the PCM were very short.
The only "sheilding" done to the car, was the addition of aluminum-backed butyl rubber sound deadening/heat shielding throughout the entire floor and firewall. Yes, RFI was a concern initially, but it seems to have worked out just fine.
Old Aug 10, 2012 | 04:14 PM
Outstanding. Your insight has given me the confidence to do it. Thanks again!
Old Aug 10, 2012 | 04:29 PM
salemetro's Avatar
No problem. Hope it all works out for ya!
