Negatives to high timing at idle?
At idle, my car likes to run a lot of timing. Usually in the mid 20s and more if cold start (26-28*). It drives great and everything though. The last time I tried to pull some or play with the controls in EFI live it seemed to run worse with less. I recall setting several of the tables to lower values but the PCM was adding more from somewhere and I never did really nail down where.
Is there any negative to having more timing at idle? I know I used to run around 18* when carbed.
I personally like running alot of timing at idle, I don't know if it's correct but I do it.
the adaptive spark might get "upside down" (more timing
from that puts you past MBT) and you get less RPM rather
than more, leading to an unstable RPM-control-loop.
Your maximum net timing should be somewhere that still
has upside, and this is base plus adaptive range plus any
active adders; determine the best timing and then subtract
the "peripheral" stuff for the base.
As long as there is nothing wrong with it, I won't feel bad leaving it alone. I've just got the rest of my tune so that I'm fairly happy with it and would like to go back and clean up any rookie mistakes that might be present.
