HELP! car wont start after BCM fix
Well i did this fix once before where you add solder to the "T" on the body control module to fix the windows/radio randomly cutting out. It started doing it again so in the process of fixing it again i accidently let the line of solder i was using touch the BCM and i heard a pop(of course like a true dumbass i didnt disconnect the battery first). I put everything back in place and now i cant start the car. When i try i hear two quick clicks that soung like they're coming from around the fuse box in the engine bay.
The radio and windows will work until i try to start it. Horn works. The fuel pump primes. The power door locks/keyless entry remote doesnt work. also the door dinger doesnt work. The security light is not on or flashing at any point.
I've checked my fuses related to starting and ignition. Do i need to buy a new BCM? or it is something else? i dont know what else to check. If i try putting in my buddies BCM in from his 95 formula that would just be a waste of time right since its already programmed to his key?
Yes im stupid and i need help fixing this. Im so pissed off at myself right now. Please help me. Car is a 97 ws6
There should be a 1 wire connector between the shock tower and battery (the purple wire doesn't connect to the battery, I'm just trying to state where the connctor is)
Pull the orange safety wire thing off, then pull the connector apart.
Have some one turn the ignition while you are measuring the end of the purple wire on the battery side of the connection. If you get 12VDC there when the ignition key is being turned to start, then all the relays in the circuit are good, and something is definitely up with either the starter or the BCM.
https://ls1tech.com/forums/attachmen...connection.gif
https://ls1tech.com/forums/attachmen...ercontrols.jpg
And please, please, disconnect your battery and then the BCM from the harness.
Searching for engine bay pics is not very good either.
Here's one:
http://www.zorly.com/images_camaro/0...oski%20Jr..jpg
If you look at the one, sole wire to the left of the ground post, that's the purple wire that goes to the starter.
when you pull off the orange safety pin, and unplug the connector, you'll be left with two ends.
The end closest to the front of the car is coming from the relay, you should have 12VDC here when someone is turning the ignition switch to the start position.
The other end goes straight to the starter coil. Jumping 12VDC to this wire, will turn the starter motor. DO NOT DO THIS IF THE CAR IS ON JACK STANDS OR IN GEAR.
You are by passing everything at that point. It's like sticking a screw drive on the start studs on older SBC cars.
I can't tell in this pic http://www.cardomain.com/ride/293872...-camaro/page-3
It might be inside a wiring loom. It should be the only thick purple wire going along that fender edge.
