Tips for tuning 231/237 cam
98 Z patriot S2 5.7 heads/231/237 tsp cam, pacesetters, 2.73's, ssf3500 is my basic combo.
lata
Bill
lata
Bill
bill,
look at my mods-cartek tune.call jason he"ll hooke you up
Thats pretty much one of the first things done on a cam tune. misfires are going to happen the lower the rpm, the more
log the misfires on cylinders and watch them fly with a cam
and improper tune.
if you disable p0300 but dont desensitize the misfire system you'll see flashing ses lights usually when idling at a light.
>>> http://ls1edit.slowcar.net/tuning.html <<
works for me , Johnny
lata
Bill
Dialing in the TB hex nut to crack it open can push it out of the idle cell?
wimped out on 7/32 ".218" but did 3/16" and now all my warm restart issues are gone.
will update on cold start. Guys what are desirable "cold/warm/hot" IAC counts? (Desired/vs/actual).
I'm gonna get hptuners shortly (car is edited already) so i can adjust this and that. Still getting surging at 1000-1400rpm locked up in 3rd or 4th. So any tips on that would be appreciated.
Only took about 10 minutes to do it since i have had the TB coolant bypass
The mod finally paid for itself...5V 0% tps 4.61V 100% TPS
3/16" hole drilled = no warm restart problems = still surging at low rpm lockup
So yeah drilling helps. I'm guessing there will be less IAC correctio when i lower the idle down, and i'll probably do 7/32 if the hptuners product allows me to idle lower (Currently set to 1000-1100rpm in/out of gear).
Should in gear be so high as well? Makes the car wanna jump off the light with no brakes.
opinions?
opinions?
GLEN added 8 mph to all the 3rd and 4th gear lock and unlock tables that were under 100 mph now car cruse very smooth - no jerking, because tc is unlockes at this points, can hear moter surging some but do not feel any jerking
GLEN added 8 mph to all the 3rd and 4th gear lock and unlock tables that were under 100 mph now car cruse very smooth - no jerking, because tc is unlocks at this points, can hear moter surging some but do not feel any jerking
i lost several MPG driving around unlocked and imagine the unlocked speed generates lots of heat due to slip heat dissipation. so i gotta tune this right.dammit judd, you shoulda waited to get your shiz, i'd have let you use my y2000 hptuners save a few bucks
Mine will be here tomorrow. I'm in the city, i assume you're out on 400. I got an office up there somewhere. Umm like 3 exits north of the northpoint mall. (not my office, my internet security company).
alot to learn. most of the example i've seen are not very good.Might want to PM HC02SS. He tuned my car for me (first car he ever tuned) and had my IAC's in the 40-50 range at idle within no time. We had to drill my TB 2-3 sizes larger. Did some kinda relearn process, did a couple of changes in the tables and baaam.....perfect.
