Spark plug readings
http://i1150.photobucket.com/albums/...z/P1010559.jpg
http://i1150.photobucket.com/albums/...z/P1010558.jpg
Backstory - it's a mild cam LS1 in a roadrace car. Engine was rebuild this spring and ran a couple times this year. Seems black to me but looking for advise if I need to make any changes in the offseason. They are TR6 plugs and were new with the engine build.
Thanks
Cameron
1. No way could those plugs be read with those pics.
2. Repeated driving cycles on the plugs, pretty much renders reading them accurately, unlikely.
Start w/ fresh plugs, make a run, read the plugs....
I see a little oil and unburned fuel but I can see no more.
If you want to diagnose something using plugs, install a new set, do a run and shut the engine off immediately after the run (don't even idle it), or else the plugs will not show any useful information.
Thanks
Cameron
Once you have AFR under control, install a new set of plugs, after the race pull them to check for proper timing and heat range.
Cameron
