LS1 barely runs, unusual circumstances. Need serious wisdom here. Where do I start?
#41
Gosh though, it doesnt even try to idle. Seriously, if I plug these o2 sensors it doesnt somehow miraculously fix it, I'm screwed. I dont wanna buy anymore parts for this damn thing. Im on a strict budget.
#43
I cant seem to get my hands on one. I dont want to spend the money to buy one. If I cant find one before the next time I go to Advanced Ill just buy it. Remember though, it ran fine WOT, which is why I havent bought the gauge.
#46
Ok guys, got the o2 sensors put in and hooked up. No change what so ever. Maybe a little less smokey and gas smell, but that's it. All together now I have a new TPS, new IAC, MAF is good, new o2 sensors... I think I am going to make a video for you guys later too. I'm thinking crank sensor might be the next thing. My timing graph looked pretty normal though. I don't have any more codes either. Starting to get pretty freaking worried here.
#47
#49
Did you get a hold of a fuel pressure tester. I would use that to eliminate fuel and then focus on the electrical system. There is only about 4 things the computer looks for to turn the car over. The Crank Angle Sensor is definitely one of them. Not sure if these cars have a cam angle sensor. You already have your MAP, MAF and Air Temp connected. Do you have access to a multimeter? You can verify voltage on all of these to make sure they are working before replacing. That should save you some money. I know it is seeming pretty helpless, but I have a feeling it is something simple that is just hiding from you. It has happened to me several times. Keep testing and you'll find the problem.
#50
100% sure these are the same factory injectors. I haven't eliminated fuel pressure as a problem yet though. Buying a gauge in about 2 hours. Only way injectors would be a problem is if it was due to the crank sensor, or cam sensor, which I dont think an LS1 has?
#51
Well got the fuel pressure tester, multimeter, and crank sensor. Unfortunately, boss man called and it sounds like I gotta go outta town for a while. To all the great guys that have subscribed to this thread, please dont unsubscribe!!! It'll be a minute before there is an update, but I might need your guys help still!!! Thanks.
#52
Ok guys, update...
Fuel pressure at the rail primes up to 62psi, and maintains 62psi while running. Drops to like 55psi when it stops priming and engine off. Holds steady there forever.
Tested every vital sensor for power and ground. MAP, TPS, Crank Sensor, but NOT the Cam Sensor. As well as all sensors mentioned are brand new, except the cam sensor which will be in a few days. Did the WD40 trick to test for vacuum leaks, none. No changes...
Now, after looking at a Chiltons' stupid *** wiring diagram I noticed that the Camshaft Position Sensor is the only sensor that ties directly into the entire ignition system? Can someone verify that for me? MAP, TPS, IAC, MAF, o2's, and crank sensor cannot shut your ignition off like what's happening to me. This cam sensor is the only sensor that I haven't replaced yet. Ordered and waiting for that. I also know that the commanded timing advances/retards are all within the parameters of normal.
Where's my freaking code telling me something isn't right here? I get cylinder 5 misfire (I think 5), EGR and AIR codes. None other than that. Had MAP sensor code, replaced it, should be gone. Oh and I reset the ECU 5 times by pulling the fuses and disconnecting the battery in case my never tuned ECU changed fuel trims itself. No change. Also called Texas Speed and talked to a tuner/tech, no help over the phone.
