Aeroforce Interceptor Gauge Owners
Old Jan 23, 2013 | 09:18 AM
  #41
Roarin_8's Avatar
Monitoring KR also with MAP on the same screen. KR randomly goes to 0.1 to 1.8 when the converter is unlocked at low speeds.... Plugs and wires are still the stockers and I have MSDs and 1 set of NGKs (lost the other set during my move). I'll see if that fixes it or else the tune will have to get looked at.
Old Jan 24, 2013 | 09:04 AM
  #42
Roarin_8's Avatar
Looks like it's false knock, rpms were going up and the KR number was going down. Looks like something is banging somewhere.....
Old Jan 24, 2013 | 09:50 AM
  #43
blake b's Avatar
I have mine set to light up if the oil pressure drops below 8psi OR if the fuel pressure drops into the 40s. My base pressure is set at 63 (I eyeballed the mechanical gauge and am going to set it to 58 when I get a retune). GM says 7psi for oil is the low end and I just picked the 40s because it shouldn't be that low except when not running... if the lights go on in the gauge set to monitor those parameters I know I need to shut the engine off.
Old Jan 24, 2013 | 12:49 PM
  #44
Roarin_8's Avatar
Thanks for chiming in regarding oil pressure and fuel
Old Jan 30, 2013 | 08:54 AM
  #45
blake b's Avatar
Be very cautious if you have the fuel or oil pressure sensors. If you don't unplug the sensor before unplugging the OBDII port connection, you will blow the sensor. If it starts reading some weird number, it is blown. The first time I blew mine, I forgot and just unplugged the OBDII connection. Two days ago, the gauge just stopped working. When I checked, the connection on the back had worked its way loose. This is blown sensor #2. I haven't been able to find a sensor anywhere (haven't really looked) other than aeroforce and they make you buy the whole kit for $75 dollars or whatever it is. At this point, I am going to not use it for fuel pressure and get another gauge (probably a prosport evo) to use for fuel pressure.
Old Feb 7, 2013 | 10:44 AM
  #46
McNair06Goat's Avatar
Only problem I'm having with the gauges is I can't read the screen of the gauge with my polarized sunglasses on. Annoying as hell
Old Feb 10, 2013 | 10:29 PM
  #47
Roarin_8's Avatar
Hmmm I haven't tried that yet.....
Old Feb 17, 2013 | 11:05 AM
  #48
Roarin_8's Avatar
Car went into limp mode P0756 code came up on the gauge. At the traffic light, I cleared the code and got back 1st and 2nd gear..... Love this gauge more and more.
Old Feb 21, 2013 | 01:38 PM
  #49
forcefedjunkie's Avatar
This was true at one time, the sensors needed to be disconnected from power when the gauge was unplugged, but we made a modification about 18 months ago (adding an in-line resistor to the sensor output) which prevents this failure. We also exchanged those sensors for about $40 if they were sent back.
Todd
Old Feb 21, 2013 | 04:31 PM
  #50
djfury05's Avatar
I have the fuel pressure kit. How would I know if it had the new inline resistor?
Old Mar 18, 2013 | 10:10 PM
  #51
senicalj4579's Avatar
Yea sorry old thread but are you guys able to read your IAC with your aeroforce? I tried today but it just reads zero. Let me know!
Old Mar 18, 2013 | 11:54 PM
  #52
xxrillixx's Avatar
I always love introducing people to these gauges... they whine about the price for MONTHS, then they install it and dont understand how they ever lived without one.
If you are boosted its a must. You will save yourself a ton of money on not damaging parts! Have the light come on at 1* of knock and get out of it. Also a good idea so you know you're probably out of meth.
I watch, TOP-BOTTOM
KR
Timing
IAT
Coolant
Dont forget you can also track misfires! it even tells you the cylinder its in! So you if ever get a burnt / bad coil pack or plug wire you know exactly where its at... especially great after a service.
I think the most important things to watch boosted or not:
KR, Coolant (99-02), timing, trans temp (if auto)
I say coolant because anyone with a 99+ fbody knows our dummy gauge doesnt tell you its overheating till you're already pulled off the road and the radiator is boiling over.
Customer service its also top notch. I dont say that often! Ive had nothing but the best service from these guys... ive had one since 08. They are excellent!!
Old Apr 18, 2013 | 03:12 PM
  #53
Kingc8r's Avatar
Definitely on my buy list.
Old Apr 18, 2013 | 03:33 PM
  #54
Alvin@PCMofNC's Avatar
LS1Tech Sponsor
We sell a TON of these gauges, they are very popular. Rightfully so...it's so versatile and install time is just however long it takes you to plug it into the DLC. I use them in my own vehicles as well...super handy.
__________________
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Custom Camshafts & Valvetrain - Remote HPtuners Tuning - Mail Order Tuning & Sales
704-307-4227
Old May 4, 2013 | 08:51 AM
  #55
99'CajunFirehawk157's Avatar
Just picked up a used one from a friend, looking for a nice single gauge pod.
Old May 6, 2013 | 08:37 AM
  #56
Roarin_8's Avatar
I bought an A/C vent block off from 6litereater. He's a sponsor on this site.
http://6litereaterdesigns.com/store/...h=166_22_36_58
Also since you have a firehawk, I believe that the gauge will fit directly into one of your A/C vents and you won't need a pod at all.
Old May 11, 2013 | 11:35 PM
  #57
Thumbs up
Just used a nice single pillar pod from summit:
Old May 12, 2013 | 12:37 AM
  #58
Zlow28's Avatar
^^^ i used to have my gauge mounted just like that on my lt1. They also have great customer service as mentioned earlier.
Old May 14, 2013 | 07:24 AM
  #59
LS-ONE_DAY's Avatar
All other Aeroforce owners, I have yet to "permanently" install mine (when I remember I just plug it in and hold the damn thing lol) but I'm curious to know how accurate the 0-60 and 1/4 mile times are. I know that that is a loaded question with tons of variables but has anybody went to the track with it set to measure and then check what it reads compared to the time slip? If not, can someone do that? I'm not in a position to get my car to the track but I'm interested in getting an idea of what it would be capable of.
Old May 14, 2013 | 08:16 AM
  #60
Roarin_8's Avatar
That would be cool if someone is able to do that.
