Picking up an 05 harness and pcm need help
Old Jan 12, 2013 | 04:42 PM
lebedin8654's Avatar
Default Picking up an 05 harness and pcm need help
I am doing a ls swap on a mustang and I have someone local selling a 4.8 with ecm and harness. I know the 05s are DBW i plan on putting an ls6 intake on it with a DBC throttle body. will the computer be able to hand this or do I need a hole different ecm and harness?
Old Jan 12, 2013 | 06:55 PM
Pacer Racer's Avatar
You will need to change the wiring to drive by cable (not a big issue) and make sure the PCM has IAC drivers in it. Even if the PCM doesn't have the drivers in it, you still use the harness and either run a 6243 PCM or switch the green covers for red ones and wire the harness to run a 411 PCM
Old Jan 12, 2013 | 08:20 PM
How can you check to see if the computer has IAC drivers?
Old Jan 13, 2013 | 11:53 AM
I found it 05 trucks do not have IAC drivers so I will need a new ecu and to repinn the wiring harness
Old Jan 13, 2013 | 01:13 PM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I can help you in any way with the wiring for your swap. Feel free to email me and I can help you get exactly what you need.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Jan 14, 2013 | 09:41 AM
wait4me's Avatar
Depends on the pcm hardware number, there where in fact some 2005 pcms with the iac drivers.
Old Jan 14, 2013 | 06:54 PM
I checked mine does not have the drivers? Where is the best place go pick up a 4.8 DBC PCM with anti theft deleted?
Old Jan 16, 2013 | 09:31 AM
omc8's Avatar
I too well need to get a reprogram , but mine is DBW Gen IV . I just need a stock tune but will need help with the repin of the harness.
Old Jan 16, 2013 | 09:50 AM
wait4me's Avatar
Just give me a call when you have a chance, I have usually 300-1000 of them in stock at any given time. I am sure I can get you what you need for cheap. Usually in the $75 dollar range. That would be with anti theft deleted.
wait4me's Avatar
What year is your harness, I may be able to email you wiring diagrams if you need something I have.
Old Jan 16, 2013 | 10:00 AM
omc8's Avatar
Its 2007 nnbs Silverado , new body style Gen IV
Old Jan 16, 2013 | 10:01 AM
wait4me's Avatar
Give me a call, I have a few options for you.
Old Mar 13, 2013 | 11:18 AM
omc8's Avatar
Ive a got ecm for tune for you , get back to me when you can !
Old Mar 13, 2013 | 11:31 AM
wait4me's Avatar
did you call?
Old Mar 13, 2013 | 11:37 AM
omc8's Avatar
Yes talked to you about month ago.
Old Mar 13, 2013 | 11:51 AM
wait4me's Avatar
I get over 200-300 calls a day, you will have to call me as I don't keep records on conversations. When you are ready, call and we can get you setup.
