how "smooth" should a VE table look like?
Old Jan 29, 2013 | 12:07 PM
greenvortec97's Avatar
Originally Posted by edcmat-l1
Set P0101, 102, 103 to 0, not 2. Then uncheck the SES enable box.
You may be in SD now because the MAF is failed, but I'm not sure. I usually set all the codes to 0, and zero out the MAF table just to be sure.
okay i will do this and do some more datalogging as time allows. Thanks for all the help everyone, I just want my car to run right and give the engine what it needs
Old Jan 31, 2013 | 09:33 AM
wait4me's Avatar
The pcm itself INTERPOLATES the cells so technically it will never by "spiky" in the eyes of the processor code. Even if you have a high cell and a low cell right next to it, it will just do a blend of the surrounding cells.
An example of this.
Cell values:...................;Pcm uses this.
10,10,10,10;..................;13,15,14,12
10,20,10,10;..................;15,16,15,13
10,10,10,10;..................;13,14,14,13
Of course this is a simple section with just a single cell change. but you get the idea. And it was an extreme example of showing double the number in one single cell, which wont happen in real life, but you get the idea.
When you have a large table with lots of data points, all cells and values are manipulating each other to achieve a valid signal.
So Choppy in the table isn't really "Choppy" But it could still be wrong.
In EFIlive there is a button you can press that will smooth the ve tables to get rid of the high points and bring the surrounding points back up to copy close to what the cpu is doing anyways. I use it often to get the ve table smooth if it is in a speed density build.
One thing I see a lot in data logging is, if you watch, sometimes if you don't fix the large spikes ever time, the spike will get higher and higher and higher as you go because it isn't the cell that is the issue, it is the surrounding ones.
Old Jan 31, 2013 | 09:37 AM
wait4me's Avatar
To add to this, I'm referencing data cpu instruction from ls1 based ecms in this.
The coefficient process of the e38 and e67 work Somewhat the same, but since data points don't really exist and it is just equations, it works just a bit different.
Old Jan 31, 2013 | 09:41 AM
wait4me's Avatar
Green, a question.
When you turn on just short term fuel trims, and you watch on your wideband, does the car tune itself to 14.6ish air fuel?
If it does, let me know and I will show you a massive shortcut.
Old Jan 31, 2013 | 11:00 PM
James@ShorTuning's Avatar
I'm with Ed, set those codes at least while tuning to verify they are tripped. You can verify this via the trouble codes. Some OS's work fine with the codes set to 2-no MIL or 3-no error reported but some do not. Just part of the different OS's being a little different than one another so it's best while tuning to make sure the codes are tripped before calibrating the VE.
Use your 3d graph view and right click and drag to rotate and right&left click and slide to zoom in or out. It is a very useful tool to use to get your VE dialed in. The smooth functions really help too.
Old Jan 31, 2013 | 11:15 PM
Guys i made the changes for the DTC's tonight before i headed off to college, the car went rich a bit, (13.0-5) at idle and 14.0-2's cruising etc. I guess i had some sort of modifier or something skewing my AFR error %, I haven't attempted the WOT area yet as i had to attempt to get my cruising cells back to 0-3's Here's two Data logs, One on the way to school and one on the way home
File Type: hpl
Old Jan 31, 2013 | 11:17 PM
Originally Posted by wait4me
Green, a question.
i will try this tomorrow morning, Am i looking at it while cruising or at idle?
Old Feb 1, 2013 | 10:22 AM
wait4me's Avatar
Both.
Old Feb 1, 2013 | 10:39 AM
Both.
it went to 15's and stayed there for both, didn't see stoich at all unless I turned the stft back off
Old Feb 1, 2013 | 10:49 AM
wait4me's Avatar
Ok. so, you can change your 02 switching points to be lower in the computer. Do that to the table, in EFIlive I know the table name, not sure in yours, but it will be a table that has like .400 .400 in columns. Change them until it gets to stoich on your wideband. "hopefully you don't have an exhaust leak near your afr sensor and it is calibrated correctly"
Then turn off long term trims, but leave on your strims. There should be a setting to turn off ltrims. But allow the car to still go into closed loop. Then log your strims on the car while you are driving with no maf. It will tell you how far off you are from what the computer wants pretty quick in all the cells as you drive. Then stop the car, and multiply and paste the difference on the strims onto your ve table in the idle and non full throttle areas. For example, if it is +3 in 1000 row and 65 kpa, then go to that section on the ve table and ADD 3 % to that exact cell. Then do the rest of them. In EFIlive, I set up maps that allow it to be a simple one click process including smoothing to make it a nice table. Not sure if you can do it in your software or not. But probably is. It makes it really quick. The key though is to make sure your base matches actual, which is what those switch point tables should do. If not those, then maybe the stoich ratio of your fuel may be off a bit, so the stoich ratio value might need tweaked just a tiny bit.
Old Feb 1, 2013 | 11:45 AM
In Hp tuners i believe its called the EQ ratio for Short term fuel trims, It's a divisor table that you use to command AFR during open loop, and i'm already in SD OL so i wouldn't need to adjust it would i?
Old Feb 1, 2013 | 01:31 PM
  #32
lsx1's Avatar
The tables that wait4me is referring to in hptuners to adjust the o2 switching points are the o2 rich/lean vs. airflow (bank 1, bank2) I believe
Old Feb 1, 2013 | 03:04 PM
  #33
wait4me's Avatar
Correct. The setting to turn off ltrims should just be a single on off switch. You still want it to go into closed loop though. So leave those settings be. Just change the ltrim off. The o2 switch points table should be able to skew them to real vs commanded in the problem areas.
Old Feb 1, 2013 | 05:15 PM
  #34
okay i found it, It looks odd for some reason, i don't think it's stock, is it?
Old Feb 1, 2013 | 05:34 PM
  #35
Depending on year and OS for the LTFT switch... some older stuff only has enable ECT for LTFT. I normally set the LTFT enable ECT to something north of what it could ever see to prevent them from ever enabling as well as disable the switch if it is present. (These are just the observations I've made with HPT) EFILives mapped parameters may be different.
Old Feb 1, 2013 | 09:33 PM
  #36
joecar's Avatar
Jesse is referring to the OL STFT Enable...
when enabled and in OL, it performs STFT trimming on any stoich cell in OLFA...
you can see this on the wideband, it looks like very tight short oscillations around stoich.
Old Feb 2, 2013 | 03:44 PM
  #37
Well guys i haven't tried the STFT method yet but i went to the 1/8th mile last night in sd open loop and i went from 7.54 @ 93.26 1.76 60ft to 7.43 @ 93.91 1.72 60ft just by datalogging the runs and changing only the WOT areas, I'm starting to see where the VE graph needs to be raised now, I guess i can see the "trend" now more or less
Old Feb 3, 2013 | 12:33 AM
  #38
ctd's Avatar
ctd
Please post the logs. The tune as well.
Old Feb 3, 2013 | 12:51 AM
  #39
Sales@Tick's Avatar
Nice gain just from some tuning!
Old Feb 3, 2013 | 02:12 AM
  #40
My6speedZ's Avatar
Nice info in this thread. Cool to see everyone pitching in, on tuning no less.
