how "smooth" should a VE table look like?
Old Jan 26, 2013 | 06:10 PM
greenvortec97's Avatar
Default how "smooth" should a VE table look like?
After 3-4 days of datalogging and multiplying my afr error % by Half over to my VE table and smoothing i am getting nowhere, it looks nothing like my dyno tune VE table 3D chart. anyone got some pictures of what it should look like? I'd love to fix my 11mpg
Also, I'm in SD open loop..
Old Jan 26, 2013 | 07:00 PM
BLK02WS6's Avatar
Here you go...
Old Jan 26, 2013 | 08:02 PM
jimmyblue's Avatar
Moderator
I really don't like that method at all, the paste-histo scheme.
You know what they say about statistics.
A histogram can get really full of transient garbage and make
the data worse than useless if you're street tuning. You want
to be more selective about what you believe.
I can't get past doing it by hand, based on segments of logs
that I select for being steady conditions and stable WBO2
readings.
In the end the motor is a fairly regular air pump and should
have no abrupt discontinuities. If you've got a porcupine
VE table, that's showing you the truth of "garbage in,
garbage out".
Old Jan 26, 2013 | 10:24 PM
readings.
garbage out".
Well, Mine surely doesn't resemble sonic the hedgehog but, up top (primarily the WOT area) i only have one small peak that i can adjust based on my WOT datalog runs, should the whole 100kpa+ area be made to match?
Old Jan 27, 2013 | 05:43 AM
khaotic's Avatar
I agree it shouldn't have huge spikes, or valleys but being perfectly smooth i believe is not the case either, I've seen many many files and tunes including files from factory Gm especially in corvette, where the table are no way smooth so to me not uncommon to see waves in the table.
Old Jan 27, 2013 | 08:14 AM
ctd's Avatar
ctd
First, are you sure the MAF is failed? I've been caught that way more than once.
The dyno VE table you speak of, was it on a load bearing dyno hitting those specific cruise cells.
LTFT's on or off?
I'm not one of those you have to tune in OL unless you are going leave OL. If you are going to run CL why not tune that with your STFT's. If there is big difference's between OL & CL of course that needs to be addressed.
Your street tuning the VE obviously, how are you collecting the data in those cells?
Old Jan 27, 2013 | 09:35 AM
edcmat-l1's Avatar
Can you post a data log and tune?
Old Jan 27, 2013 | 10:48 AM
James@ShorTuning's Avatar
First off its a good idea to tune in open loop pending you have a quality wideband... I've seen instances more than not that the narrowband sensors don't target exactly stoich and the setpoints themselves need adjusted to accurately target stoich after modifications have been made. Most of those cases are larger cam setups with plentiful overlap.
Steady state is required to adjust VE accurately. This is where a loaded dyno to hold the engine at a steady rpm while varying load and adjusting the table is the most precise way of doing it.
Now on to your question does it have to be smooth? Smooth is normally the result of what the engine wants. Don't smooth the table to make it "look" good, adjust the table to what it wants. Once finished you will see a trend of smooth contour from low load to high load. Some camshaft intake and header configurations will cause a certain rpm to drop VE or raise VE. The most notable occurence I can think of is 5.3l trucks. They generally want a ridge or ditch all the way up the (if memory serves) 1600rpm column. Smooth that out to the 1200 and 2000 column and you get excessive rich condition. So in the end give the engine what it wants. The only thing I know that should be smooth is up the load point. You are not going to flow more air at 50kpa @2000rpm than you do at 55kpa @2000rpm. So keep that in mind when building a VE table.
Old Jan 27, 2013 | 11:07 AM
Like I said, I've only just started messing with the WOT part of the table. Both logs are from this same tune file, MAF is set to fail as well. If there is an error that I could have made please inform me, I'm trying to get past this hurdle. With the Dyno tune the car had, it gets horrible mpg, the injector data was all sorts of wrong and AFR bounces all over the place while cruising..(13.0-15.0) with my SDOL tuning attempts I can get a solid constant AFR number.
Also, i run a PLX AFR gen 2 wideband with the bosch 14.2 sensor
File Type: hpt
File Type: hpl
Old Jan 27, 2013 | 11:22 AM
yes sir it's up now
Ill check it out when I get home tonight. When you do cruise down the highway try to keep your rpm as close to the column rpms as possible. Filter out throttle transients when you make adjustments. It takes longer but quality data is needed to accurately dial in the VE.
Old Jan 27, 2013 | 11:48 AM
Good deal, thanks in advance James!
Old Jan 28, 2013 | 01:06 PM
anything guys?
Old Jan 28, 2013 | 04:12 PM
qqwqeqwrqwqtq's Avatar
readings.
garbage out".
I agree and have seen plenty of VE tables that make no sense at all. I manipulate the brake on the dyno to go as near to steady state in each cell I can get to then use those trends to build the VE table which I blend by hand.
Once I get WOT to equal commanded AFR and everything closed loop to within a few percent of zero on the fuel trims it is finished.
This is what a typical mild naturally aspirated setup ends up looking like-
Old Jan 28, 2013 | 07:53 PM
way to make me feel bad haha! You guys have years with this stuff under your belts. i only got a week lol.
Old Jan 29, 2013 | 08:17 AM
mterveen's Avatar
intmd8 - i'ld love to see what a turbo one looks like that you have done. the one you posted is just beauuuutiiffullll!
Old Jan 29, 2013 | 08:47 AM
ctd's Avatar
ctd
Does not look like you are in SD.
Old Jan 29, 2013 | 09:06 AM
what do i need to fix?
Old Jan 29, 2013 | 09:54 AM
Going to look somewhat similar. Just remember for the VE table to deliver proper fueling it will follow the torque curve. Combo's that are more high rpm oriented will have a VE table that corresponds, meaning it will carry out flatter at high rpm rather than dropping off (as more high rpm torque is being produced it needs more fuel to maintain the proper ratio).
Here's an example. This car was tuned by a local shop and came in with this-
-And left with this, part throttle air fuel perfect, WOT a/f ratio exactly matching commanded at every boost level and correct transients. You won't accomplish that with huge dips and holes in the table. It just has to make sense.
Old Jan 29, 2013 | 11:49 AM
edcmat-l1's Avatar
Set P0101, 102, 103 to 0, not 2. Then uncheck the SES enable box.
You may be in SD now because the MAF is failed, but I'm not sure. I usually set all the codes to 0, and zero out the MAF table just to be sure.
