how "smooth" should a VE table look like?
Old Feb 3, 2013 | 10:15 AM
  #41
greenvortec97's Avatar
Originally Posted by ctd
Please post the logs. The tune as well.
Here's the current tune, after the track i loaded up the dyno tune and drove home, i haven't made any changes to it yet, Been really busy but this is what all happened, On the burnouts i went lean everytime so i can see where that hole area needs to be raised up
also, does PE need to kick in RIGHT when the TPS reads 100%? because i was seeing low 14's down low at the track on launch then they went to 12's
I haven't messed with timing at all yet, still a flat 26, I haven't seen any knock retard at all either
Also, on the VE table, Across from the WOT area that little spike ahead of it is my burnouts that had to be raised up because i was going lean , Does this whole area in red need to be raised? Im guessing this is where the Brake on a dyno would come in handy. I still don't know what I'm going to do with the area in blue yet
And on this one the blue circles are areas that i had to fix for the burnouts, I'm guessing I have to make the sorroundingl areas around the same values to avoid lean spots
Lower part is the only area i was able to make changes to at the track
File Type: hpt
File Type: hpl
File Type: hpl
Old Feb 3, 2013 | 01:27 PM
  #42
ctd's Avatar
ctd
I still don't believe you are SD, I'm guessing Ed is the only one that has looked at your tune. You might want to review his post again to insure you've failed the MAF.
Also, Airflow>Dynamic>High RPM Disable, you have that @ 2000 rpm?
Fuel>Power Enrich>Cold, You have TPS @ 65%. That means you are not into PE until your TPS is 65%.
You could set the scanner up differently for drag racing, more like a dyno. Your logging some things that are not necessary & missing some important ones.
Old Feb 3, 2013 | 02:05 PM
  #43
Yes, is this not correct? I've never messed with it
what is the general % that most people have theirs set to?
I read a tuners blog about dynamic cyl air and another parameter that i can use as a "street dyno" I'll be giving this a try shortly
This stuff is giving me a headache lol
Old Feb 3, 2013 | 02:16 PM
  #44
ctd's Avatar
ctd
No pain no gain,
Old Feb 3, 2013 | 03:00 PM
  #45
No pain no gain,
lmao, alright so set the high rpm disable to redline then?
Old Feb 3, 2013 | 03:03 PM
  #46
ctd's Avatar
ctd
Here is a screen shot how you might set up your scanner. This was a MAF only deal I was playing with. Disable chart 3 & you are looking @ how you may tune on a dyno. Chart 4 shows DynCylair, that is your torque curve. Then the MAF or Dynamic air for HP.
Not the best example but helps visualize what you can do.
Old Feb 3, 2013 | 03:08 PM
  #47
ctd's Avatar
ctd
Yes & No, 12,800 rpm & zero out the MAF table.
Old Feb 3, 2013 | 04:10 PM
  #48
Okay done, will try this again tomorrow since i tore the intake manifold off today
Also, Those PID's, are they custom? i can't set them up right for the life of me.. Dyn Cyl Air isn't even an option for me
Old Feb 4, 2013 | 04:46 AM
  #49
joecar's Avatar
To ensure the MAF is failed a MAF DTC should be present.
Old Feb 4, 2013 | 05:11 AM
  #50
joecar's Avatar
Won't this cause steady state MAF contributions (from the MAF table containing zeros)...?
Old Feb 4, 2013 | 07:02 AM
  #51
ctd's Avatar
ctd
Duh, yes! I was really trying to stay out of the thread as there has been so many excellent posts.....I didn't want to clutter it & worse give a wrong instruction. Whoops!!
Old Feb 4, 2013 | 01:09 PM
  #52
joecar's Avatar
No worries... this stuff is mind twisting even on a good day.
Old Feb 4, 2013 | 04:03 PM
  #53
you can say that again.. lol!
Old Feb 4, 2013 | 07:21 PM
  #54
ctd's Avatar
ctd
I think it's more like a brain aneurysm!
