Looking for the trigger wire for LS-3
Old Feb 8, 2013 | 11:11 AM
The Corvette Kid's Avatar
Default Looking for the trigger wire for LS-3
I have a ls-3 in my 61 Corvette with a GM harness and I need to find the trigger wire on one of the ign. coils to power my Speedhut tach. There are 4 wires to each coil harness, does anyone know which one is the trigger wire. my tach is programmable so all I need is the trigger wire from one ign. coil. For some reason it won't read the tach signal from white tach wire on the ecm. Thanks, Bob
Old Feb 8, 2013 | 11:56 AM
wait4me's Avatar
Pin c on the coil is usually the right one.
Old Feb 13, 2013 | 05:20 PM
How do I know which one is pin C on the coil, is it marked. Thanks, Bob
Old Feb 13, 2013 | 06:32 PM
85MikeTPI's Avatar
What ECM are you using? The E38 ECM is tried/tested to power factory and aftermarket tachs with some settings and a pull-up resistor.
http://www.hptuners.com/forum/showthread.php?t=36611
IMHO, stay away from cutting coil wires. I've seen several systems code when trying to tap them for a signal.
Old Feb 18, 2013 | 06:09 PM
LS1MCSS's Avatar
The connector will be marked with tiny little letters.
Old Feb 19, 2013 | 09:10 PM
Thanks, I will take a look. Bob
