Curing the "reduced engine power" TAC issues.
Old Mar 7, 2013 | 06:39 AM
rumblebox's Avatar
Default Curing the "reduced engine power" TAC issues.
Immediately after selling my 03 silverado to a family member, it starts going into reduced engine power mode with a TAC code. So far i've replaced about 6" of wire to the TB connector and soldered the wires into the terminals. That didnt help.
Ive also seen where people replace the TAC, TAC module, pedal sender, etc etc with no luck. I'm about to replace all the wires from the TB to the TAC module and see if that works.
Before they start throwing parts at it.... Does anyone have access to the service bulletin?
Old Mar 7, 2013 | 02:43 PM
edcmat-l1's Avatar
What codes? Specifically.
Old Mar 7, 2013 | 02:45 PM
rumblebox's Avatar
Name a few and I'll recognize it.
Old Mar 7, 2013 | 03:09 PM
edcmat-l1's Avatar
How bout you scan it so you're not guessing. Post up the codes it's setting, and maybe someone can help.
Old Mar 7, 2013 | 03:21 PM
BLK02WS6's Avatar
Generally ends up with the TB needing replaced on those trucks...
Old Mar 7, 2013 | 03:42 PM
rumblebox's Avatar
Because it happened to me a year ago, and i turned off the process enabler with EFI live, not knowing it was hardwired into the PCM, in hopes that it would stop. So now it does it without throwing a code. It's been so long i don't remember which code it was, but if i see it, I'll know.
I do remember it was not one of the P15xx module codes.
Old Mar 7, 2013 | 05:18 PM
BLK02WS6's Avatar
See attached - 1514 through 1518
Attached Thumbnails Curing the "reduced engine power" TAC issues.-truck-codes.jpg
Old Mar 7, 2013 | 05:20 PM
rumblebox's Avatar
P1516
Old Mar 7, 2013 | 06:32 PM
sreve's Avatar
Originally Posted by rumblebox
P1516
Here's a trouble tree
File Type: pdf
Old Mar 8, 2013 | 09:03 AM
wait4me's Avatar
Try a different throttle body, Those things get weak after a while I have seen. The brushes on the inside get chewed up a bit so it looses its torque.
