Frost Tune...Now IAT Problem?
If I disconnect the IAT, it will start and run just fine. If I connect the IAT while it's running, it will immediately die. Same problem with a new IAT, since the old one broke after disconnecting it multiple time. I'm quite stumped...
Car is a 99 Z28 with just headers, ORY, exhaust and a 3600 stall. Just simple stuff.
read harness voltage if you can't. ECT is a primary factor
in enrichment for open loop / startup. IAT will also index
this, but a faulted IAT might eliminate all the cold enrich
(there's some stuff that's "X vs ECT vs IAT" tables.
I've seen vehicles with bad ECT connectors that act all
flakey and over-enriched.
Also give us some diagnostics so we can help or the tuner can help out like post sensor reading, what are your IAT or coolant reading, 02 readings, alot of variables, check and post what your voltage readings at the sensor connectors.
