Lingenfelter 2-step install - Car Won't Start
I'm installing an LNC-001 and I have it all wired up, but my car won't start. The unit powers up when the key is on, but the car will not crank.
I have a 2002 Z06 (manual). Has anyone else had any issues like this? Any thoughts.
Thanks!
Thanks!
The 2 step only disables spark when activated, it can't modify anything else.
Even if the unit is malfunctioning the car should crank.
The only thing that can prevent cranking is the clutch position sensor, if you didn't hook it right the car will not crank.
Check your wiring, you have something wrong
Seemed to work fine for me and used very few wires, just some weather pack connectors and some solder.
