PCM communication problem
Old Jul 25, 2013 | 07:49 PM
shrike's Avatar
Default PCM communication problem
Hi,
I tried to post this in hybrids but not much luck besides a helpful member who tried to see if I did the basic steps of trouble shooting. Here goes my problem:
I have a 1999 4.8 with a 4L60E RWD and the computer coming from the 4.8.
These all are installed into a GM D-body. I also have an electric fan.
The car runs, for the past three weeks I have been using it every day the weather is nice.
The problem is I cannot communicate with the PCM when I try to plug an OBDII scanner. I have tried it with two scanners. I have the OBDII plug out of a 1999 truck so the pins are at the same locations. I checked that I have two grounds on pins 4 and 5, battery + on pin 16 and data signal on pin 2. I get an error when I plug the scanner.
How can I know I get a signal on pin 2 from the PCM?
What is the voltage I should get on pin 2?
How can I make sure the PCM works properly?
Can the car run fine but the circuit for the OBDII communication be damaged?
I read that one sign the PCM gets damaged is when the fan starts with the key on. I remember once the fan kicking in when I just started the engine and I found that weird. But it only did it once and everything seems to run fine.
Any tips?
Thanks
Old Jul 25, 2013 | 08:28 PM
ACCLR8N's Avatar
I had a similar problem on an LT1 swap. One of those ground pins on the OBD2 connector must be connected directly to a specific ground coming from the PCM harness.
I hope you are probing the signal wire with a high impedance volt meter for electronics. The car will run fine without providing communications to a scanner.
Old Jul 26, 2013 | 07:34 AM
shrike's Avatar
Thanks for the reply,
I will check again for the ground but I don't remember seeing that information. I only read until now that it has to be a good ground but that's it.
I am not sure what kind of voltmeter I have. I will verify that also.
But is there any way to know if the problem is from the computer being fried or is it just a programming glitch?
If I probe the signal wire and if the computer is fine what shoud I read on my voltmeter?
Old Jul 26, 2013 | 09:00 AM
Ed Wright's Avatar
9-Second Club
If your volt meter has a needle on it, do NOT use it. Nor a cheap digital with less than ten mega-ohms impedance.
Old Jul 26, 2013 | 09:21 AM
shrike's Avatar
Thanks,
I will check the impedance on it. It does not have a needle.
I'll also try the trickle charger tip tonight. Haven't heard of that one yet, I just read about it.
Old Jul 26, 2013 | 04:31 PM
shrike's Avatar
I tried the charger thing....doesn't work
This is also the meter I am using:
http://www.mtpinc.com/Products.htm?NL=1&CD=78&ID=217
Any ideas what else I should try or should I go for anoter PCM?
Thanks
Old Jul 26, 2013 | 09:24 PM
Ed Wright's Avatar
9-Second Club
Have you tried your scanner on another vehicle? Do you know anybody with a '99 through '02 4.8, 5.3, or 6.0L truck, or '99 through ' 02 LS1 car? If it communicates with their vehicle, try plugging your PCM into their vehicle to see if it communicates. Don't need to start it to test that.
Old Jul 27, 2013 | 06:22 AM
shrike's Avatar
I tried the scanner on my wifes's Vibe and it worked. I also tried another scanner on my car and it did not work. Unfortunately I don't know anyone with a truck or car, I was thinking of trying something like that.
Old Aug 26, 2013 | 11:40 AM
shrike's Avatar
I was finally able to try another PCM. The scanner connects to that one.
So it is really a problem with my PCM. I find it weird though that otherwise the car seems to run fine.
