truck harness with 2000 fbody pcm. What needs to be done?
I have a drive by cable truck harness and a 2000 TA PCM. What do I need to do to make them work together? Repin a few pins on the harness? If so any diagrams?
Ok, it's a engine swap?
If you already have the harness, it may be easier to just flash the PCM to match the year/vehicle of the harness, no need to repin.
If you are changing the wiring regardless, use the best operating system for your needs
Compare the 2 wiring diagrams to see the differences, there will be a few.
If the Fbody is the same year as the PCM and you need everything else to work (cluster for example) your best option is to keep the tune the PCM already has and repin the harness to match the car/pcm.
You can use it as is, but a few things may not work, like fuel gauge.
