HELP! 98 Z28 tries to start and throws crank sensor code. Please help
Old Nov 8, 2013 | 09:53 PM
mustang93's Avatar
Default HELP! 98 Z28 tries to start and throws crank sensor code. Please help
I have a 98 Z28. The car cranks and tries to start. Only getting spark to 3 cylinders. And fuel to all. Fuel pressure checks out. It keeps throwing p0335 and p0336 crank position sensor code. I replaced the cam and crank sensor still the same issue. I also checked all the grounds. Anyone have these issues before??
Old Nov 9, 2013 | 07:47 AM
mustang93's Avatar
Anyone?
Old Nov 9, 2013 | 08:21 AM
MontecarloDrag's Avatar
Check wiring from PCM to sensors, you may have a broken wire
Old Nov 9, 2013 | 04:09 PM
mustang93's Avatar
All wires are good.
Old Nov 9, 2013 | 04:13 PM
dreww's Avatar
Check voltage on those sensors u replaced. Mayke sure they are getting power, ground and signal to pcm
Old Nov 9, 2013 | 06:45 PM
mustang93's Avatar
Ok. I checked all grounds and 12v at the PCM. But not getting any cam sensor signal from brown pcm wire. But if I hook the test light to the positive aide and probe the wire and crank it over it back dires real loud.
Old Nov 10, 2013 | 08:57 AM
dreww's Avatar
Ok, break in that wire somewhere. If u have to, hard wire a new line from pcm pinout to sensor.
I always get them confused. Cam and crank sensors. But one out will cause a no start, the other will cause a hard start with backfire, usually cold engine. I believe bad crank sensor signal is no start, bad cam sensor signal is hard start with backfire.
Old Nov 10, 2013 | 06:50 PM
mustang93's Avatar
My reluctor wheel has some chewed up spots. Could that be my issue. The kicker is im pretty surebwhen I built the motor over a year ago becsuse of a broke rod it had some bad spots but I could be thinking of a different one??
Old Nov 10, 2013 | 07:53 PM
joecar's Avatar
The LS1 (GenIII) CKP signal has to look like this (see attached)...
Attached Thumbnails HELP! 98 Z28 tries to start and throws crank sensor code. Please help-ls1-ckp-vs-cmp-signals.gif
