Tuning Noob in need of some advice
Thanks.
[] P0452 - Fuel Tank Pressure Sensor Circuit Low Voltage (Pending) (Old) (Current) (Immature)
[] P0650 - Malfunction Indicator Lamp (MIL) Control Circuit (Pending) (Old) (Current) (Immature)
[] P0740 - TCC Enable Solenoid Circuit Electrical (Pending) (Old) (Current) (Immature)
[] P0785 - 3-2 Shift Solenoid Circuit Electrical (Pending) (Old) (Current) (Immature)
[] P1860 - TCC PWM Solenoid Circuit Electrical (Pending) (Old) (Current) (Immature)
Im still getting those codes though. I wonder if by chance he put a 4l80 in it. There are two larger green wires that go into a plug on the drivers side of the trans that are not hooked up. Im guessing those are a for a neutral safety switch?
Does any of that have the potential to be a problem with fuel supply when I know the pressure and volume are within spec of all the research I have done?
