4l80 lockup issues attached current tune
Old Dec 3, 2013 | 10:36 AM
k5383's Avatar
Default 4l80 lockup issues attached current tune
0411 PCM
LQ9
4L80E
FTI 3K converter
The computer won't lockup the converter on its own, however It can be commanded to lock and it will via HP tuners.
I'm having a friend tune it with HP tuners, and I personally am not that knowledgeable as to what exactly he's done.
Does this sound like a tuning issue, or more of a internal trans problem? I've also got this posted in the auto section with no responses as of yet.
I know the misfire table needs to be raised to compensate for the cam, and larger (smaller diameter) converter, not 100% sure if that's been done. Just want a better knowledge base to bring to him when I can get the truck back to him.
UPDATE at bottom reply
Old Dec 3, 2013 | 01:01 PM
tommyboy's Avatar
my buddy is having similar issues with his 4l80 setup. We can clear all codes and the lockup will work, but after a short drive something is setting off the random misfire code which eliminates the lockup ability. It can be manually commanded with a tech2 but chasing down this misfire is getting annoying! I'll have to check and see if his tuner raised the threshold for misfire codes, because he also put an aftermarket stall on. Other things that have been replaced:
-plugs
-wires
-injectors
-coils are next on the list
Old Dec 3, 2013 | 01:10 PM
k5383's Avatar
It's good to hear I'm not alone with this. I also have new plugs, wires, and injectors.
The coils are used, but I'm getting no trouble codes other than not having a check engine light.
Old Dec 3, 2013 | 01:16 PM
tommyboy's Avatar
yeah he was getting 2 specific coils for misfire, which could of been the coil or injector. He had a brand new set of injectors so he threw those on and got a retune but the lock up is still acting up. Hopefully the 250k mile coils are the problem, he just ordered some new ones so i'll let you know if that fixes it or not.
Old Dec 18, 2013 | 08:05 AM
k5383's Avatar
Ok, update... my own HP tuners finally came in, misfire tables are maxed out already (so I believe) I also think* I adjusted the lockup to come on in 4th at 42MPH
However it still doesn't lock on its own, I can however command the lockup and it happens.
I've attached my current tune, hopefully I still don't have it correct?
File Type: hpt
Old Dec 18, 2013 | 09:10 AM
Russ K's Avatar
Your TCC min duty cycle table is all 0's. Change it to 90.
Russ Kemp
Old Dec 18, 2013 | 09:41 AM
k5383's Avatar
Russ Kemp
90 for all the cells correct? I downloaded some tune from the repository for comparison and it's the attached screenshot.
I've set them all to 90, going to go flash the truck and give it a whirl!
Old Dec 18, 2013 | 10:38 AM
k5383's Avatar
Flashed with the table being all 90's no lockup.
Copied table shown in screenshot into tune, reflashed, again no lockup.
Yet with either tune lockup still happens when commanded.
Old Dec 19, 2013 | 10:21 AM
k5383's Avatar
HP tuners board pointed out I had my release speeds higher than my apply, changed those as well and still doesn't lockup?
Old Dec 24, 2013 | 09:54 AM
Sarg's Avatar
How do you have the transmission wired? Like a 4l60 or a 4l80 with a segment swap? Sorry can't see tune from phone.
Old Dec 25, 2013 | 11:35 AM
k5383's Avatar
The wiring harness was built for a 4L80, it started as a non electric trans harness. The fella who I had build it added the 4L80 portion in.
Old Dec 26, 2013 | 08:55 AM
Sarg's Avatar
Do you have a segment swap for a 4l80?
Old Dec 26, 2013 | 09:04 AM
k5383's Avatar
Doubtful, The last person I had street tune the truck flashed it from the non electric trans to the 4L80.
I bought my own HP tuners trying to fix this issue, is there a way I can tell if it has a segment swap?
Old Dec 26, 2013 | 09:26 AM
aknovaman's Avatar
Read this for segment swap numbers.
http://www.hptuners.com/forum/showth...-Segment-swaps
There is another post somewhere that tells exactly which segment is for trans, trans diagnostics, engine and engine diagnostic etc but i can't find it now.
Old Dec 26, 2013 | 04:32 PM
k5383's Avatar
I took a screenshot of my current "Calibration Details" looks like, Says I've got a 6.0 with 4L80.
That mean when the previous tuner built my tune from a correct base, or it has a segment swap?
Sorry if I seem dense, trying my hardest to comprehend all of this. lol
Old Dec 26, 2013 | 04:44 PM
mike13's Avatar
curious how do you know it doesn't lock?
Old Dec 26, 2013 | 05:01 PM
NicD's Avatar
7 Second Club
Your three TCC release TPS tables are zero'd and they should be populated with 100s? Your file doesn't need a segment swap if it started out already an 80 operating system.
Old Dec 26, 2013 | 05:47 PM
k5383's Avatar
Cruising at 55 I can blip the throttle barely and the RPM will jump 4-500 RPM.
If I go into the command center, I can "turn on" the TCC solenoid via this button the RPMS will drop as if the converter actually locks.
See screenshot for the actual button I'm referring to.
The TCC tables have been altered since the last tune I uploaded, I also had it pointed out to me I had several (all probably) DTC that had to do with the transmission turned off. Those were turned on, and all set to the SES on 2nd recognition.
The attached tune is exactly how it sits today, if I'm not mistaken the tables pointed out have been altered. I actually copied a fellow members trans tables into mine hoping the trans would lockup as he said his does. Yet to no avail.
File Type: hpt
Old Dec 26, 2013 | 08:27 PM
Sarg's Avatar
I wonder if the trans is wired at the ECU correctly? Here is a copy of my start up 3 bar SD tune with the 4l80e segment swap done. Feel free to check it out and see anything you might be able to gain. I know for a fact that mine does lock up.
Old Dec 27, 2013 | 12:09 AM
k5383's Avatar
There's a chance it's wrong I suppose, but I'd like to believe it's correct.
The gentleman whom built it do it for a side business, used to work for gm, and is a member on here.. Ha
I'll check out your tune tomorrow night when I've got time.
Preciate the help
