Need help or advice with HPtuners
that is the correct inj flow rate vs kpa data
VE doesnt look that bad but could use help since you are at 13.0 afr and the pe commanded is much lower than that, low 12s.
spark table looks fine IMO.
^^This are the numbers that show up when I added those, it automatically changes them when I edited them, Any reason why??? Thanks SUBEONE, I appreciate it!!!
