Cold start super rich!!!! 3bar SD
There is no wideband signal, so no way to know if it's rich or lean.
If your datalog is correct, then something is wrong because there are injector duty spikes of more than 400% at idle and the engine is seeing high loads at low RPM. At idle the cylinder airmass should be like 0.20, but you are in WOT areas so the PCM will enrich the mixture.
The MAP readings are strange, too little vacuum (which may be caused by the engine running poorly or bad MAP settings), the timing advance seems high for idle too.
Fuel pressure and injector settings must be checked.
Not much can be advised without taking a look at the tune
For starters return the timing tables to stock, you are commanding a lot of timing at idle and high load-low rpm areas with no reason. Only test to see if the idle and startup improves, don't go WOT. I'm sure you will see a lot of improvement with stock timing tables
Also, the idle airflow tables have a lot of air, return them to stock (Base idle airflow and startup idle initial)
Cammed engines need more timing to idle properly, but a lot of timing isn't good
