Iac counts stuck at 0
Old May 10, 2014 | 01:43 PM
red2000z28's Avatar
Default Iac counts stuck at 0
Car doesn't want to idle. Put it in gear and it won't compensate for load and dies. Iac's never change. Tps shows 0% at closed and 100% at wot like it should. No codes are being set either.
Old May 10, 2014 | 02:11 PM
99z28383's Avatar
Have you tried cleaning it with carb cleaner? It could just be stuck..
Old May 10, 2014 | 06:17 PM
red2000z28's Avatar
Yep. Tried that. Still won't idle properly. Still shows 0 counts
Old May 10, 2014 | 06:43 PM
red2000z28's Avatar
Iac valve doesn't even throw a code when unplugged.
Old May 10, 2014 | 10:31 PM
99z28383's Avatar
Do you have your throttle body idle screw adjusted correctly? Maybe the IAC is faulty, but you would think it would throw a code.
Old May 10, 2014 | 10:50 PM
red2000z28's Avatar
Never touched the set screw.
Old May 11, 2014 | 07:53 AM
Old Geezer's Avatar
Vac leak???
Old May 11, 2014 | 10:25 AM
red2000z28's Avatar
Intake has new gaskets. All vacuum lines hooked up. Can't think of where else to check.
Old May 11, 2014 | 11:19 AM
93camaro_zzz's Avatar
Have you tried maybe "commanding" a certain IAC count. You can do that with the VCM controls. Try commanding like 60 counts or something while logging IAC and it should respond and show 60 counts. If it does not, then I would almost guaranteee it is bad or stuck. My next course of action after that would to measure voltages at the plug.
Old May 11, 2014 | 01:38 PM
red2000z28's Avatar
I don't have hp tuners. I'm using my scan tool to look at everything. I'm gonna pull valve covers and check my rocker bolts. Maybe one of them didn't seal when I put engine back together.
Old May 11, 2014 | 02:27 PM
Oh I see. Well in that case I would start measuring some voltages then.
Old May 16, 2014 | 04:33 PM
red2000z28's Avatar
I went ahead and got a new iac valve and tps sensor. Car idles much better now. Old iac valve was stuck closed. Iac counts still stuck at 0. Resealed all the intake rocker bolts. It idles fine but iac still not doing its job. No counts. No codes when I unplug it or anything. Car was tuned before when PO had it. Wondering if some hack did it. Can you turn off the iac valve in the PCM?
Old May 17, 2014 | 09:04 PM
jimmyblue's Avatar
Moderator
Maybe the RPM control loop is disabled (you can, by
jacking the enable temperature, at least; probably
also by giving it a bogus RPM target or ruining the
P, I, D control values.
IAC counts is a "push" from the PCM; there is no
feedback about real position.
Old May 18, 2014 | 10:02 AM
red2000z28's Avatar
I pulled intake and the intake ports are coated in oil. I think it still has a vacuum from the rocker bolt holes. Have the ls6 pcv valve do I don't think that's the source.
