Predator help
Old May 18, 2004 | 01:02 AM
HAMRHEAD's Avatar
Default Predator help
I have a predator and wanted to know what parameters I could change to help my car run well enough to get it to the shop for it to be dynotuned. The shop is about an hours drive, mostly freeway. It is a H/C install but has all the bolt ons and new 30# SVO injectors. I've heard of people having real problems keeping the car running when all this is changed. I just need to get it to the shop then they will do a complete tune.
Old May 18, 2004 | 02:37 AM
Tiger2o69's Avatar
Hey hamrhead can u turn the codes off that make the sencers go off from not having cats w/ the predator.
Old May 18, 2004 | 03:00 AM
HAMRHEAD's Avatar
I never tried it with a cat delete myself but yes you are suppose to be able to with the predator. You can scan and delete codes.
Old May 18, 2004 | 10:53 AM
Tiger2o69's Avatar
Thanks,
Sorry I couldnt help you
Old May 18, 2004 | 11:04 AM
ataylors's Avatar
I doubt the predator will be of any help, the injectors are going to be hard to work around. what are the cam specs?
Old May 19, 2004 | 03:58 AM
HAMRHEAD's Avatar
224/228 112lsa
Old May 19, 2004 | 08:48 AM
ataylors's Avatar
why did you change the injectors?? Should be able to run fine with that cam. Just drill the TB for better idle and less dying
Old May 20, 2004 | 12:29 AM
HAMRHEAD's Avatar
There's more than just a cam. It's a H/C package pretty much all the bolt ons and N2O.
Old May 20, 2004 | 09:19 AM
ataylors's Avatar
the only way the predator is going to help with those injectors is if you email them for a custom tune, I doubt you get it in time though
