olsd tuning maxed ve table
Old Jul 16, 2014 | 07:23 PM
erskine's Avatar
Default olsd tuning maxed ve table
so i just got my car running and i get the idle dialed in at 14.7afr. but soon as i touch the gas spike like and stumbles. i have a afr error histogram made and keeps saying it wants more fuel and i max it out at 445. so i check intake bolts and tb for a vacuum leak and i got nothing. so i keep adding fuel and still lean need help
added scan at bottom
Old Jul 17, 2014 | 08:17 AM
LSX Power Tuning's Avatar
You definitely have something wrong mechanically or so something fuel related in the tune way off. Are you running stock injectors? Checked fuel pressure?
Old Jul 17, 2014 | 09:04 AM
SladeX's Avatar
Stop trying to compensate fueling with the tune. There seems to be something seriously wrong with the tune OR there is a mechanical issue. From LS1 stock/cammed/bolt on heads -> LS3 cammed, there is not nearly as much change from my stock LS1 tune in most settings. Ie, changes in timing, VE etc are actually not far from each other or just shifted into different RPM ranges due to cam characteristics.
Do some logging, post the tune and log here so we can give you some input on what may be happening.
Old Jul 17, 2014 | 11:37 AM
danieloneil01's Avatar
post the tune
Old Jul 17, 2014 | 12:37 PM
2xLS1's Avatar
Ball bearings. Everything is ball bearings these days. I would get some 3-in-1 oil and some gauze pads. Lots of gauze pads.
Unfortunately that's all I can suggest with the details you give in your post.
Old Jul 17, 2014 | 03:22 PM
joecar's Avatar
lol, ball bearings.
Sounds like the procedure is being incorrectly followed.
Old Jul 17, 2014 | 06:03 PM
erskine's Avatar
fci 1000cc inj, fuel psi stay constant it on e85, return fuel system, dual intake e85 pumps, 408ci, super vic
Old Jul 17, 2014 | 06:13 PM
erskine's Avatar
tune tune
File Type: hpt
Old Jul 18, 2014 | 03:52 PM
directnosfogger's Avatar
I haven't look at your tune but I'm just gonna take a shot in the dark and say either you are not actually in open loop if you keep making changes but no difference or you are running strictly MAF
Old Jul 18, 2014 | 08:49 PM
erskine's Avatar
No maff. Super vic with 4150 tb
Old Jul 18, 2014 | 08:56 PM
Russ K's Avatar
Your injector flow rate & offset tables are set up for a returnless fuel system. If your pressure regulator is vacuum referenced, then the offset & flow rates should be the same at all manifold vacuum.
Also your stoich is still at 14.68, should be around 9.75
Russ Kemp
Old Jul 19, 2014 | 08:48 AM
erskine's Avatar
thanks russ, ya i was tring the afr both ways(14.7 and 9.7) to see if it made a difference at all
Old Jul 19, 2014 | 12:09 PM
erskine's Avatar
scan, at first its fine and everything smooth. then its goes lean and everything gets choppy
File Type: hpl
Old Jul 19, 2014 | 12:58 PM
2xLS1's Avatar
Histogram shows that at 1000 rpm it is flowing 1.0-1.04 g/cyl of air. You have something seriously wrong with your air model. I haven't had time to look at the tune but something has to be seriously whacked.
Old Jul 19, 2014 | 01:15 PM
jimmyblue's Avatar
Moderator
Are you sure the wideband meter is not having a problem?
I have had the LM-1 act normal at first and then sort of
"lock up lean" some time into the session, when the LSU4
sensor was on its way out.
Chasing bad data will seldom give a good result.
Old Jul 19, 2014 | 02:04 PM
erskine's Avatar
wb seems ok, when wb goes lean the car sputters
