Wiring Fuel Pump Relay to Grn/Wht Wire. Wire is always hot
Hey all,
I'm finishing up my harness modifications for my LQ9 BMW E36 swap. There's one thing i can't seem to figure out. I've looked at the pinouts a million times. I'm using the green with white stripe wire from Pin 9 of the red connector. I've looked at my bin, and i believe it's set to 30 seconds fuel pump run time before start (which seems REALLY long, but it's a totally stock file untouched aside from VATS removal). The fuel pump relay control wire stays hot. It never shuts off after 2 seconds, 30 seconds, or any amount of seconds.
Any ideas? IDK why this would matter, but some of the sensors aren't plugged in at the moment (crank position sensor is the only one i could possibly imagine that could affect this as maybe the PCM thinks the car is running?)
Input is greatly appreciated!
-Jordan
-Jordan
