actual vs. commanded timing
what else pulls timing? I checked the spark tab in hp tuners and IAT can pull timing, but only at intake temps above 100 deg. this scan showed 72 deg IAT.
Does the PCM pull timing to maintain the actual AFR to commanded AFR? This is the only other thing I can think of. Despite the timing pull (or perhaps because of it), the car does maintain commanded AFR thru the WOT pull and runs great.
The only thing I can think of is its using the low octane table, but only for the 4800rpm cells. That also doesn't make sense, wouldn't it use either the HO table or the low HO table? not pick and choose which table it wants during a pull?
I copied high table to low and scanned again. the timing came back and so did KR. I think Im just getting shitty gas, even though we have 93 octane here and I always fill up with that. Time for chevron, shell or similar I think.
in the 5200 and 5600 rpm timing is a little higher. about 24 degrees
this knock was only at WOT, I have no partial throttle knock. ill have my laptop and attempt to post the scan tomorrow. thx
